Question about Macally BTMicro Mouse
Configuring bluetooth 2.0 @ BtMico Mouse
How to install/config Bluetooth 2.0 dongle and Macally BTmicro mouse in Windows Vista? Thanks...
Posted by hcao on
Thomas Christopher
    Genius:
  • 1,601 Answers
Not supported for VISTA yet.
Posted on Nov 23, 2007
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
May 09, 2011 | Computers & Internet
My bluetooth usb wont work on my laptop .I usein vista and it tells me that it is a toshiba stack
Initially check whether the drivers for the blue tooth is installed or not .
This can be seen from the device manager if there is no drivers installed for it install the drives needed for it by using the cd provided with the blue tooth.
.After installing the drivers when u plug the dongle you have got led blinking inside the device if the led is available .
if the above steps give you positive result sure your bluetooth will work. if not there may be some problem in the device
Mar 10, 2010 | Macally BT-SYNC Bluetooth (BTSYNC)...
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
Oct 24, 2009 | Microsoft Windows XP Professional
My PC does not have bluetooth. Hw do i download one
You will need to purchase a blueetooth dongle.EXAMPLE below
http://cgi.ebay.co.uk/NEW-NANO-Mushroom-USB-2-0-BLUETOOTH-ADAPTER-DONGLE-EDR_W0QQitemZ220477537048QQcmdZViewItemQQptZUK_Computing_Networking_SM?hash=item33557c3b18&_trksid=p3286.c0.m14
Sep 14, 2009 | Microsoft Windows Vista Ultimate Edition
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
Bluetooth not installing on WinXP
I looks like Acer designed this Notebook for Windows Vista only.
Have you wiped Vista and installed XP instead? If so is there a particular reason, like an old piece of software not working with Vista?
I would be inclined to put Vista back on it. Vista is much better and safer than XP once you get used to it, Especially on a laptop.
If you really want to keep XP, try looking for an older Acer notebook with the same bluetooth adaptor that came with XP installed and see if the driver works from that, its a long shot though.
Andy
Jun 26, 2008 | Computers & Internet
Bluetooth class 2 dongle
here are some sites in which the bluetooth dongle drivers for vista are available just download it from here for free........
www.exwell.com/support.html
www.telusplanet.net/public/wladykad/
www.dev-toast.com/2007/01/05/uncrippling-bluetooth-in-vista-rtm
www.dirfile.com/medieval_bluetooth_diagnostic_tool.htm
www.fulldownloads.us/free-full-download-bluetooth+usb+dongle+driver+vista-crack-serial-keygen-torrent.html
yzoo.co.uk/search/web/mikomi+bluetooth+driver+vista.html
www.radarsync.com/vista/vista_more.php?result=400
www.mobilefun.co.uk/cheap-jabra-bluetooth-dongle-vista-driver-download.htm
www.bonphi.com/download.html
www.nodevice.com/driver/company/Gigabyte/Bluetooth_network.html
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Open Questions:
Macally BTMicro Mouse Logo
177 people viewed this question
Top Macally Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Chinmay Joshi
Chinmay Joshi
Mike
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
