Tablets & eReaders Logo
r
rudd Posted on Sep 13, 2017
Polaroid tab will not connect to wifi - Polaroid Tablets & eReaders
My Polaroid P9 tablet will not connect to my wifi.
Try it near your router when connecting to WiFi
Why does a Polaroid 7 tablet not work on wifi when all connected just keeps saying retry
Hi Have U tried logging into Google for all the apps U need like Google drive : etc... good luck
To many patten attempts
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Dropped tablet, screen is rainbow
How can I get my Polaroid S8 to connect to a WEP encryption wifi router without changing the router security?
I cannot get my tab 3 which is brand new to even see my wifi at home. it says it is not in range. i have been able to connect to some free wifi in other spots. help!
I read something about manually adding a wifi spot...Don't remember where it was but try Samsung dot com
go to your wifi page and do a search will progressively getting closer to you modem... if it doesn't see it in range at all, check with your internet provider as something may be conflicting... I've had no problems connecting to my home wifi or wifi spots all over the state of Florida and I have the same Tab. Wonderful product and you will enjoy it. Also some apps are made for mobile phones only and will not work with the tabs... keep this in mind
My polaroid tablet is conntected to the wifi but says failer to conntect to server
Did you verify the wireless is enabled and connected to your network?
A lot of tablets will auto-disable the wireless when they go to sleep.
8helpful
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
1helpful
Polaroid Tablet wont connect to Wi Fi
6helpful
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Top Polaroid Tablets & eReaders Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
