Click on the trash can icon and press delete
Testimonial: "I want to empty the Trash Can on my phone ... the only icons at the bottom of the screen are + compose , search and menu when I am in the Recycle Bin. There are 600 odd deleted messages in there and I want to delete them from my phone!!!!"
SOURCE: recycle bin
Try fixing it by using System Restore. Just pick a restore point that is dated before the recycle bin became corrupted. Also, you may be the victim of a kind of virus called recycle f**ker it puts a file in your recycle bin that can not be removed and is invisible...
SOURCE: recycle bin got deleted
go to control panel double click system then click system restore choice the C: then click ok set the restore point the time before you delete the recycle bin
SOURCE: Missing recycle bin
To delete apps you can also use shift+delete key.
This will permanently delete the app..
If you need anymore help let me know..
SOURCE: Windows Vista Ultimate: Recycle Bin
If you find that when your Recycle Bin does not refresh but shows the same icon, irrespective of whether it is empty or full, here are some trouble-shooting steps you can try. Hopefully, one of these 5, should help you.
1) Check if you have installed any Theme or an Icon Package, and see if uninstalling it makes the problem go away. if so then the problem is in the Theme or Package. Also try switching the theme to Windows Classic theme and them back to Vista Aero default.
2) Right-click Desktop > Personalize > Change desktop icons > Disable / Uncheck Recycle Bin. Then click Restore Defaults. Click OK. Reboot. Now using the same method Enable /Check Recycle Bin, then restore defaults. Click OK. Refresh Desktop.
3) In the 'Desktop Icons settings' Dialog Box, check on Recycle Bin.
Then click on the ‘Recycle Bin Empty’ icon.
Click on 'Change Icon' tab.
rom the new box which opens, select the icon that shows the 'Recycle Bin Full'.
Do the same for 'Recycle Bin Full' icon.
Change it to 'Recycle Bin Empty' icon.
Now click Apply.
Now check whether, when the Recycle Bin is full, the empty-icon show. And vice versa.
If it does, go back and again change back the icons, to what they should be, using the same procedure, mentioned above.
4) Use the Group Policy Object Editor.
Type gpedit.msc in Vista's Start Menu Search bar and hit enter.
User Configuration > Administrative Templates > Desktop > Remove Recycle Bin icon from desktop > Double click on it > Enable > Apply Reboot.
Next, follow the same above-mentioned steps. But this time instead of 'Enable' select 'Not Configured.
See if it helps.
5) Repair or Re-build the Icon Cache. For this the easiest way would be to download and use TuneUp Utilities or Stardocks Icon Packager. They are not freeware, but you can use the trial versions to get your job done.
SOURCE: cant empty my s3353 recycle bin..i have four file
we have the same problem and when it get full the files that u want to delete wont be deleted instead it get hanged and u need to get the battery just to make it off.
