Question about Lanier Office Equipment & Supplies
I'm trying to put a new toner cartridge in my Lanier LD430c. I followed the instructions, but the printer still tells me that the black toner is empty and I have to add toner.
Posted by D Wong on
richie46
    Top Expert:
  • Lanier Master
  • 12,962 Answers
Check on mfg site for reset procedure on printer.
Posted on Sep 13, 2017
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Posted on Dec 07, 2007
Anonymous
SOURCE: "toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Posted on Jan 24, 2008
Anonymous
  • 214 Answers
SOURCE: How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Posted on Feb 09, 2008
Anonymous
  • 1605 Answers
SOURCE: Toner Cartridge empty
does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Posted on Jan 06, 2009
Anonymous
  • 49 Answers
SOURCE: cannot remove toner cartridge
There is a manual removal option. Open the front cover. Then the top. Remove the drum. Close the front cover. (leave the top open). Move the toner housing unit so the required toner is accessable from the back. Remove.
Replace drum. Restart printer. The housing unit shoud rotate the empty spot to the front so you can insert the new toner.
Good luck.
Posted on Feb 27, 2009
Why after we change the toner it will not print
after refill the toner may be bias charging roler is not proper fiting
or toner cartridge is not proper insert
Aug 18, 2014 | Lanier Ld445c Ld435c Ld430c Ld425c Ld420c...
Dell 3000cn Printer
I think the following instructions are quite clear. In any case, before giving an inappropriate rating pleas contact us. Thanks for trying rating should be used only for unhelpful solutions and I do not think these here are the cases. Please follow the instructions from point six:
6 - Connect the printer to power and turn it on
7 - The toner cartridge carrier rotates and then stops. After confirming
the Insert Black Toner (K) message, open the front door.
8 - Hold the tape on the protective cover and gently pull it forward to
remove the cover from each cartridge slot. You only have to remove the
cover from each toner cartridge slot the first time you use your printer.
Toner will be present on the roller.
9 -
10 - Lift the tab up 90 degrees and pull the toner seal straight off, keeping it
parallel with the toner cartridge.
cf252ec.jpg 11-
To insert the toner cartridge, face the label on the cartridge to the front
and align it with the arrows on the printer. Guide the cartridge until it
snaps into place and then push down the handhold to lock the cartridge
in place.
12 - Close the front door. The toner cartridge carrier rotates to the next
empty slot. When the color of the newly inserted cartridge appears on
the display, followed by the Insert message, insert the next toner
cartridge. Repeat steps 6-11 until all cartridges are installed.
Here is the link to download tha manual:
http://support.dell.com/support/edocs/systems/3100cn/he/placemat/3100cn_setup_diagram.pdf
Hope it had been helpful, let me know if you need further support
Feb 15, 2008 | Dell 3000cn Laser Printer
Lanier LP235c display says Add Yellow toner
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Aug 04, 2012 | Lanier 5235 Printer
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
Trying to replace the empty black toner cartridge. I go through the steps to do this as outlined in the manaul. I get the screen that tells me "Please Wait." And I wait and wait and wait, and nothing...
Instead of following the directions as outlined in the manual, to have the printer turn the drum so I could extract the empty cartridge, I cut out a couple steps, by just reading the printers status display window. Followed the links that took me to where it said Replace Empty Toner Black, pressed the Menu Select button, and was given the OK to open the lid and door and replace the empty cartridge.
Sep 20, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
where x is:
c=cyan= 6,600 pages
Jan 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Samsung scx 4216f all in one printer
Searching on Google on how to access the fuse I found a page that showed you how to reset the counter without replacing the fuse. It was simple, access the TECH menu and select NEW CARTRIDGE. Here are the instructions:
[menu] - [#] - 1934 - [menu]
Then select “NEW CARTRIDGE”
Restart Printer to get out of the TECH menu.
May 11, 2007 | Samsung SCX-4216F All-In-One Laser Printer
165 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
