2 or 3 stage compressors normally run at a constant speed
the stages are from different size pistons
1st stage is a large piston for low pressures that feed to a second smaller piston for higher pressures and for 3 stage to an even smaller piston to get really high pressures
for example 1st stage =100psi
2nd stage =1500psi
3rdstage =3000psi
your manual should explain the set pressure for the compressor if the compressor speeds up , that is a two speed unit
