SOURCE: Onan 4kw Emerald I generator will not crank
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Operation of a Devilbiss GT5000 generator
not to familiar with the generators however , I do know that the old style receptacle for 240 volts was three prong. Then OSHA got a hold of it and added a second ground to make it 4 prong, Thats why some houses use a 3 prong dryer cord and some use a 4 prong. hope this helps. and if it has 2 240v outputs BONUS they dont make em like they used to.
Testimonial: "Thank you for the answer. Electrical stuff is my weak link. If you need to know anything about investing in the markets I'll return the favor."
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
SOURCE: 5500 generator stopped producing eletric after
First check with the
dealer and see if it is still under warranty. If it is not, make sure nothing
is blocking the air flow around where the control modules are located. This
could cause the voltage regulator and other electronic parts to overheat. Next
check the brushes and make sure they are free of any dust or build up preventing
them from making contact.
If everything is OK the
next thing I would do is change the voltage regulator.
SOURCE: Faulty Generator
check for open armature (check continuity at slip rings). Also check that diodes are good (not opened). Engine RPMs should be at least 1800 or 3600 depending on alternator. Probably 3600 RPM (for 60hz).
Also check to see if you have a bad circuit breaker.
