Can I convert a Yamaha EC 5000DV generator to electric start? Where can I get those parts. rich
You can convert it BUT.... It will require spending almost as much on parts and shipping as this generator is worth.
You will need a new flywheel. Wiring harness for the start circuit, Key / switch assy, modified contgrol panel, Starter & solenoid, mounting bolts, a battery and battery holder. Additionally you will will need a voltage requlator.
Each of the parts will have to be special ordered from a Yamaha service center type shop. There is not a kit form for your unit. Depending on exactly which engine you have the 357 CC or the 410 CC you may not even be able to do it at all.
I just looked into doing the same thing for a Robin RGV 6100. "The dealers have you by the private parts!!!" The cost was about $200.00 less than buying a new generator of the equal size with an electric start system. The only thing I would not have had to buy for that conversion would be the regulator due to it being an inverter generator type unit.
Thanks for using FixYa.
Kelly
