Optics Logo
m
manuel shirley Posted on Sep 12, 2017
On a meade lx5 i just bought it has a des motor drive which works but it doesn't move the scope can you tell me whats wrong
5 Related Answers
Anonymous
  • 1952 Answers
  • Posted on Oct 09, 2008
SOURCE: Meade LX 200 spins around non-stop when powered up
click this link
Meade Autostar Feedback','www.weasner.com');">http://www.weasner.com/etx/archive/feedbackMay03/autostar.html
http://www.debunker.com/astro/rtgui.htm
Anonymous
  • Posted on Dec 05, 2008
SOURCE: rifle scope is hitting 5 feet high but dead center
mounts are probably too high.....had the same prob on a .22 rifle with high mounts for open site shooting also. i bought a lower mount and zeroed it in with no prob
Experi
  • 20 Answers
  • Posted on Aug 15, 2009
SOURCE: problem with start up on telescope
Most probably, flat batteries. Autostars go berserk when batteries are even a little low. Try it with a mains power adaptor instead.
Otherwise, maybe its a dodgy curly cable, broken Autostar, broken control panel or Autostar firmware needs reloaded
Joe L
Joe Lalumia aka TelescopeMan
  • 3186 Answers
  • Posted on Jan 28, 2010
SOURCE: Meade lx-90 dec printed circuit board bad. where
Since you already disassembled the scope-- you can send the board to Ron Sampson and he should be able to repair it. He fixes main boards and hand controllers (including the screen and keyboard on the hand controller!)
If you post a message on the Yahoo LX90 group looking for Ron Sampson he will answer you. You can then email or phone him for instruction on how to send him the board.
ARE YOU SURE it's the board? It could be a bad keyboard or a bad cable on the hand controller. You should get another hand controller and cable and test it before you send it off. Can you borrow a hand controller and cable from anyone.... or from a local scope retailer?
Testimonial: "tHIS GIVES ME SOMEONE ELSE TO CONTACT SO IT WAS VERY HELPFUL."
Joe L
  • 3186 Answers
  • Posted on Feb 21, 2010
SOURCE: Meade ETX 80 telescope missing parts
You are missing a screw on cap for the rear port, and you need to buy several 1.25 inch eyepieces.
Scopestuff.com sells the rear port cap also you may be able to get one directly from Meade- http://www.meade.com/support/index.html
Several internet retailers sell 1.25 inch eyepieces.
Here is one:
http://www.agenaastro.com/
Testimonial: "Thanks Joe! As it turned out I was also missing the 90 degree eyepiece holder."
I have a Meade ETX-70. When turned on, the handset says there is a Motor Unit Fault: Motor failure detected due to moving handset between scopes, low battery level, obstructed or overloaded scope. I've...
This is usually caused by low battery power-- as the hand controller reported. DO NOT USE rechargeable batteries they do not have enough volts. Use alkaline batteries only.
This can also be caused by a broken gear or a failed internal motor. You can return these to Meade for repair.
Here is the contact number:
I was given a Meade DS2130 reflector. Everything seems to work fine except the scope doesn't move in Altitude. The motor works fine and the white horizontal worm gear and vertical white gear turn...
ONLY Meade will have parts-- usually they want you to return the mount to them for repair-- call them here:
www.telescopeman.org
www.telescopeman.us
Aug 28, 2011 • Optics
Meade DS 2000 Goto Reflector scope. I am looking for the base goto motor assembly housing witch houses the motor and gears. Can anybody please help?
You cannot actually get parts for this scope other than from Meade directly-- and possibly a USED motor on Ebay. Usually Meade wants you to send in the scope for repair and will not sell you any gears or motors.
www.meade.com
Hi I have a meade ETX 105 pe I can get the scope to move Alt motion with the controller but it wont move in the Azimuth position with the controller. Might I be doing something wrong
This can be caused by 4 things-
A stuck button on the hand controller.
A bad hand controller cable
A burned out circuit board inside
A burned out Azimuth motor
(Long shot) bad firmware in the hand controller. DO a Reset and reload the firmware.
Try to borrow another hand controller and buy a new cable. If these two do not fix it then it's a mechanical problem or a circuit board problem inside the scope.
Meade can repair this but you will need to send them the scope:
1helpful
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
Hello, i just rec'd my used meade 125etx ec scope.
Contact Meade directly. You may need to send it back for repairs. Here is the contact web site:
I took apart the vertical support arm and need to insure that I am putting it back together properly as it will not currently move vertically, horizontal is ok
Here is the manual-
http://www.meade.com/manuals/TelescopeManuals/Reflectors/DS2000%20manual.pdf
If the motor does not work it can indicate-
A broken wire inside
A broken altitude motor
A broken motor control circuit board
Only the first one listed above can be fixed by you. The scope must be returned to Meade for either motor or electronic repairs.
Here is Meade's customer service web site:
1helpful
I have a meade lx90 8inch 3 years old with autostar 497--when i try to raise the scope up it keeps drifting down also having problems with intermitant slewing on set up-both motors working ok
This is called "rubber-banding". Your scope needs to be re-trained.
So, setup a target during the day at least 100 feet away from the scope (200 feet would be better, Calibrate motors using the same power source you use at night, and Train Drives. Later after dark, do a Calibrate sensors on Polaris.
You should train drives about once per year, and calibrate sensors about twice per year.
You may want to update the firmware before you Train Drives. The latest version is 43Eg available on the Meade.com web site. You with need the Autostar Updater Software also available on the Meade web site under Customer Service---- Downloads. Version 5.9
www.meade.com
Need instruction manual for 1996 or 1997 etx 90 basic model
The manuals are all available to download from www.meade.com.
If your scope has the motor drives and a control panel into which a controller could be plugged, then you just need to buy an Autostar 497 - always available on eBay for about £85. However, there are older models of the ETX which only have one motor or as a spotting scope for terrrestrial use with no motors - Autostar cannot be connected to these.
Look at the pictures of scopes on eBay which come with Autostar - if your looks like these, Autostar will fit. Else you are out of luck!
Top Meade Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Meade Optic Expert? Answer questions, earn points and help others
