Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
SOURCE: problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
SOURCE: Amp burning speakers.
one of the channels your using may be burned out or there is sum wire touching inside the amp so take the cover off and make sure nuthn is touching and see if sumthn is burnt and also try using a different channel on the sub
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
SOURCE: i have a pyramid pb 880 1000 watt 4 channel amp
it is more than likely that your rca outputs are bad
This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
The single sub channel is created by bridging channels 3 & 4
