Question about Samsung Cameras
Samsung Camera WB350F was acting erratic when trying to take pics. Now when trying to turn it on only the green power indicator goes on but the camera does nothing.
Have to take battery out to turn green light off. A couple of people have told me these cameras have firmware and software issues.??
Posted by Manny Ace on
5 Related Answers
Arpi
Arpad Kothai
  • 326 Answers
SOURCE: Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 24, 2007
Anonymous
SOURCE: no power
Not sure if this is related, but our's won't start-up either, and it seems to indicate that the batteries are weak/dead prematurely. There must be some sort of power level controller that could be the root problem. Our experts can add some useful content to both these threads....
Posted on Aug 22, 2007
Anonymous
SOURCE: My camera shuts off immediately after I turn it on.
Have you changed batteries?
Posted on Oct 21, 2008
Anonymous
SOURCE: Put new batteries in camera,
you must use the right batteries
Posted on Jan 10, 2009
Anonymous
SOURCE: Battery drains after a couple pics taken
this happens to mine aswell, does your camera playback sound on your videos, as when waching my videos there is no sound. please help.
Posted on Aug 09, 2009
Multi indicator light flashes red then green but camera won't turn on - VPC CA8EX
The condition you described is usually a problem with power to the circuit board in Samsung cameras. I know you mentioned the battery but try the following:
1. Ensure battery is good
2. Remove the battery from the camera.
3. Let the camera sit with the battery removed
for approximately 60 minutes.
4. Clean your battery contacts on the battery and in the camera with a clean cloth, or Q-tip dampened with alcohol or contact cleaner.
5. Reinstall the battery and try to power on the camera. If your camera still doesn't work it will need to go in for service.
Dec 30, 2014 | Samsung Video Cameras
My computer recognizes my micro sd card when it's in a card reader, but not when it,s in my samsung wb350f camera
For every device you connect to your computer, the computer needs a program and a driver. So insert the CD that came with your Samsung camera, and install the program and driver.
That should solve the problem.
First install, then connect. Don't leave the camera connected while installing.
Success
Dec 04, 2014 | Samsung WB350F Smart Digital Camera,...
Camera will not transfer to iphone or ipad after last apple update 8.0 but did before. What setting got screwed up? Camera is Samsung WB350F
I'm not familiar with Samsung digital cameras. How did you initially transfer photos from camera to iOS devices? Is it possible to save the photos on your computer and then transfer them to iPhone/iPad via iTunes? How to Transfer Photos from Computer to iPad
Sep 24, 2014 | Samsung Cameras
CAN NOT DELETE PICTURES ON MY SAMSUNG SMART CAMERA WB350F
connect it to a computer and you should be able to delete anything you want
Aug 13, 2014 | Samsung WB350F Smart Digital Camera White
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
Optio 33LF LCD problem
This often indicates a card error. Transfer all your images then format the card in the camera. If you still have the problem, try a different card. If you still have the problem then looks like you will have to send it in for repair.
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Cameras Logo
64 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
