Question about Rotel Televison & Video
I bought a used rotel rsx 1067 without a remote not delivered yet and i want to use it as a pre amp will it be ok with the front panel button
Posted by jocelyn leduc on
2 Related Answers
Doldog
  • 222 Answers
SOURCE: Hi i have a Rotel
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
Posted on Sep 28, 2010
Tom Chichester
  • 55379 Answers
SOURCE: I recently bought a Rotel RSX 1067 surround receiver. I am tying to play through the front speakers 2 CH function but the sound is weak
The speaker impedance may not match that of the receiver.
Posted on Dec 21, 2016
How to connect my Bose 901 series vI speaker to yamaha rx v740 and rotel rb 1582. Appreciate your help. Thanks
The Bose controller gets wired in series between the pre-amp and the power amp.
I presume you plan to use the 901's as the front L&R pair. So the cables going from the 740's Pre-Out Front L&R go to the inputs on the Bose controller. The outputs of the Bose controller go to the power amp Front L&R channel inputs.
Aug 17, 2014 | Audio Players & Recorders
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 02, 2014 | URC-Universal-Remote-Controls Remote...
Where can we buy the remote of RSX 1067 7IN1
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Jan 18, 2014 | Rotel Audio Players & Recorders
Hi i have a Rotel Rsx 1067, powers up then off, the remote control is using new batteries, the receiver pickups the remote sensor but doesn't do nothing. volume control does not adjust up or down, and when...
Good luck
Sep 28, 2010 | Rotel RX-965 Receiver
Hi, I have a Rotel 1050 receiver that I am trying to hook up to a NAD 2400 THX amp. I do not know how to "bridge" the connections so that the Rotel amps are not disabled. Any help is appreciated.
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Apr 10, 2010 | Rotel RMB-1095 Power Amplifier
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
My Rotel RSX-972 surround sound receiver has no power, the repair centre cannot isolate the problem and they do not have a service manual to guide them,a service manual would be handy??
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
Mar 25, 2009 | Rotel RX-965 Receiver
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Televison & Video Logo
129 people viewed this question
Top Rotel Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
deton8 von Splosion
Tom Chichester
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
