Computers & Internet Logo
Question about Palm Computers & Internet
With 64 byte Palm Pilot, does hot sync only work with a new cable? Also is Hot sync only one way, desktop to hand held?
Posted by John Bergesen on
5 Related Answers
Anonymous
  • 473 Answers
SOURCE: hot sync operation cancelled (8001)
Try replacing the cradle or if you can install Palm desktop on another computer and try synchronizing on it. This is usually a sign of a week cradle or COM port on your computer.
Posted on Sep 12, 2005
Anonymous
SOURCE: hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Posted on Apr 04, 2008
Anonymous
  • 448 Answers
SOURCE: Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Posted on Jan 01, 2009
ctau
castletech
  • 372 Answers
SOURCE: hot sync
Try changing the HotSync settings
Select Desktop overwrites handheld for each conduit
Posted on Mar 20, 2009
Anonymous
  • 1884 Answers
SOURCE: I had a power flicker
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Posted on Nov 02, 2009
Got a new computer with windows 7. Downloaded latest software for palm. It won't sync with my tungsten e handheld using a usb cable. I have all the latest information in the desktop software on another...
well i had the same problem, and the problem turn to be that the latest software is ****! uninstall that software and install the palm desktop 4.14 that should do it! its sound like old but its the same thing!
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
1helpful
2answers
Can I hot sync z22 palm without the touchscreen?
The data on your old Z22 is very likely very secure, and the touch screen problem is very common - there are a few tricks to get the touch screen working long enough to transfer the data.
I have a web page entirely for maintaining, repairing, and interfacing your Z22 at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
You can try these tricks, or just replace the screen for $9 U.S., since the screen only needs you take the unit apart and flip open a connector lock ...
I would strongly advise getting a solid plastic cover over your new Z22, since this is the key to keeping the screen working...
hope the information is of help to you
good luck
robin dusty graves
Z22 PALM PILOT hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg hot-sync-z22-palm-without-touchscreen-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg
1helpful
Hot sync
Hot sync treo 650 Zip-Linq cable
I have a desktop dell runining XP software. I have a tungsten E hand held. I cannot get the contacts on the handheld to appear on the screen of the desktop. I just tried putting a new contact in the desk...
Try right click on the Hot-Sync icon, on the Taskbar and select Custom then select Address book and change the Action to Synchronise the files. You might have to use Windows Explorer to view your contact. I'm not 100% sure about this one but try it anyway.
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Hot sync operation cancelled (8001)
Top Palm Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
