Question about Samsung Cameras
My Samsung WA456DRHDWR/AA has no power - Samsung Cameras
Posted by Cindy Bunn on
Tony Parsons
  • Samsung Master
  • 6,280 Answers
This is not a camera it is a washing machine. Reposting in a forum dealing with domestic appliances may give you more assistance.
Posted on Sep 11, 2017
Testimonial: "Reposted directly with correct information."
My Samsung washer model WA456DRHDWR/AA doesn't have any power. Need help troubleshooting.
Hey Cindy,
First, makes sure all the breakers have been reset and do not trip when you try to use the washer.. if the breaker trips each time you try to use the washer, then you need to cal a qualified repairman..If the breaker is good and stays on, make sure its plugged in correctly..if its plugged in and you have power at the plug..( are you mechanically inclined?).. if not call the Qualified repairman)..there are several things that will cause it not to work,,
Samsung WA456DRHDWR AA User Manual Check These Solutions If Your Washer...
http://www.appliancepartspros.com/repair-help/samsung-washer-wa456drhdwr-aa-0001-repair
check this out..
Samsung Recalls Top Load Washing Machines Due to Risk of Impact Injuries
Sep 11, 2017 | Samsung Washing Machines
Error code BE1 comes up at spin time & it stops. Common cause?
8e1 Front mems sensor error locates on main board check at main board fir loose harness. Probably a bad sensor or harness get both the sensor itself is under too near front right
Apr 09, 2016 | Samsung WA456DRHDWR: 4.5 cu. ft. King-Size...
My drum has come loose from the bottom where the agitor is how do I get it apart so I can center it again?
I would guess that the bearing is loose or bad.If you lay it on its side you should be able to see whats wrong
Oct 05, 2014 | Samsung High-efficiency Top Load Washer...
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
This Samsung AA-PB9NS6B battery maked with Hi-Quality battery cells, which is guaranteed to meet OEM specifications. All Samsung AA-PB9NS6B laptop batteries on sale have passed the strict quality control...
Samsung gets their batteries from a supplier, just as newbattery gets them from their source. The OEM or original equipment manufacturer set the specifications and thus the battery was made accordingly. 30 day warranty is standard and after that, your on your own.
Mar 05, 2014 | Samsung DLP HL-P5663W 56" TV
Can u give me batteries specifications please?
The Samsung website just says: Primary Battery: 2x AA Alkaline
So any AA will be ok.
You can also use:
Rechargeable battery(0ptional) :
SNB-2512
SBP-2524
Jul 02, 2009 | Samsung Digimax S500 Digital Camera
Cameras Logo
41 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
