Question about Husqvarna Sewing Machines
Husqvarna viking 950 not running. Replaced foot control and still not working. Machine powers up. Slight wiggle in one of the posts on machine foot pedal cords connects to.
Posted by Risea Nelson on
sales402
    Problem Solver:
  • 27 Answers
This problem is most likely a powersupply board problem, you can contact [email protected]
Posted on Jun 30, 2019
5 Related Answers
Anonymous
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
Posted on Jul 24, 2008
Norm Himebaugh
  • 152 Answers
SOURCE: I have a Husqvarna Viking 2000 SL and it seems
The first thing to check is the pedal itself. If you have a continuity tester you can check to see if a connection is being made in the pedal when it's being stepped on.
You can also turn the handwheel back and forth while you step on the pedal with the power to the machine on. If the motor starts to run a little bit, you know the pedal is good and the motor carbons will be bad.
That machine's rear cover over the motor comes off somewhat easily, so you could also check the connections in the electric terminal where the foot control plugs in. Make sure to have it unplugged when you do this part. Gently move the wires near where they connect to the terminal block and see if any are loose. There are screws there that tighten onto the wires that sometimes loosen which would make your pedal not work.
Posted on Oct 09, 2009
dupina
Theo du Preez
  • 110 Answers
SOURCE: Husqvarna Viking #1 use same foot pedal as the #1+ ???
Yes it will work, you can go ahead and purchase it.
Posted on Jan 22, 2008
RichSew
Douglas Plant
  • 222 Answers
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Posted on May 27, 2010
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
SOURCE: why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Posted on Mar 27, 2012
I replaced the foot control on my Husqvarna Viking Model number 545 and still have problem with it not seeming to get the message to run.
I just got a great answer to the same question. If you are sure the cord is conducting electricity it may be the contacts in the machine. Check for lint on pins. If they wiggle a little you may have to remove back and tighten the screws that hold the machine wires in place.
Sep 11, 2017 | Husqvarna Sewing Machines
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Are you sure the cords are not broken inside the wiring? It happens to lots of electronic things.
Lost power control foot pedal viking scandanavia 100
Hello
You may be able to obtain a replacement foot pedal from you local Husqvarna Viking dealer.
Happy Stitching
Sewingirl/
Jan 28, 2014 | Husqvarna Scandinavia 100 Sewing Machine
Husqvarna model 183 foot control no power
anytime the machine does not respond like it's suppose to then it needs to be checked, the foot pedal could have gone bad, or the the sewing machine plug where the foot pedal goes may have gone out
Mar 27, 2012 | Husqvarna Viking 1
Presser foot control -- Viking Husqvarna #1 sewing machine
May 23, 2010 | Husqvarna Viking 1
I have a Husqvarna #1 that I also love. My needle stopped moving too. I was convinced it was the foot peddle but a repair person sais it was not. I discovered on my own that indeed it is the cord on the foot peddle. I suspect it has a loose wire because when I wiggle it where it connects to the machine it starts working again. Right now this is what I have to do because I can't find a replacement peddle. Can anybody help me find one?
Jul 06, 2008 | Husqvarna Viking 1
Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
Jun 02, 2008 | Husqvarna Viking 1
Sewing Machines Logo
91 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
