Question about Lexmark Office Equipment & Supplies
I have a Lexmark X1250. It has been working perfectly and all of a sudden it prints incomplete pages from Excel and prints blank pages from Word. Prints from pictures.
Posted by Annette Thorold on
5 Related Answers
Anonymous
  • 417 Answers
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Posted on Jan 28, 2008
Anonymous
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
priya sabharwal
  • 7 Answers
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Posted on Dec 04, 2008
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: Prints a blank page only
First try to clean the cart with following procedures if this did not work then heat walls of the cart with hair dryer for 3 to 5 min then insert the cartridges and try to print :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 19, 2009
luciana44
Lissa Nixon
  • 292 Answers
SOURCE: Printer prints blank pages from notepad, word, and excel.
Hi tim8094
Obviously there is nothing wrong with the printer, because you are able to print from the Internet.
Before attempting to print from word, excel etc, make sure you have the correct printer selected (check it through FILE MENU -> PRINT ->PROPERTIES)
Do a print test by typing just couple of words -may be in different color-
Best of luck
luciana44
Posted on Sep 22, 2009
In Excel I have page breaks and wish to hide some pages but when printing the hidden pages print as blank pages and print preview jumps from page before and page after but includes the hidden page num
Don't put anything in blank pages, not even a space, now select the pages those you want to print and print selection.
It must help you out
It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Aug 02, 2014 | Microsoft Excel for PC
Lexmark X1240: tried to uninstall and reinstall
Please make sure that the printer is actually VISTA compatible (it should say it on the box) If it is compatible then there is a good chance that the drivers need to be updated. (even if you just bought it) Your first option would be to download the driver directly from Lexmark.com (forget the CD that came with it) Your other option is to download the drivers for LEXMARK X1250 (I have tried this many times with other printers and they worked just fine) I have also used these two web sites to download the drivers for other printers and it seems to work ok so far. Here are the links to the X1250 http://driverzone.com/device.php?id=81664 http://www.siliconguide.com/drivers/device/112/ ...Best of luck to you, I hope I was able to help.
Apr 24, 2010 | Lexmark X1240 All-In-One InkJet Printer
When I print from excel the page comes out blank
ok... here are some general tips... in your print driver make sure that it is set to spool documents... it gathers everything and then prints... make sure the print driver isn't shared from a server... servers are famous for distorting excel printer communication.... it isn't the konica... its a print driver excel conflict...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 11, 2010 | Konica Minolta bizhub C250 All-In-One...
My Lexmark x125 all in one only prints blank pages
configure the proper port for the printer if you using usb cable for printer select the usb port in the properties of the printer ......
check the port you configure to printer
Oct 06, 2009 | Office Equipment & Supplies
Printer is printing blank pages
Before printing any page, Click on print preview optioon in the file menu and check whether the page has all data.
Thanks, PREM
Mar 22, 2009 | Lexmark X6570 InkJet Printer
Lexmark X1250 suddenly won't print
ok..turn off the printer..and unplug from computer..let it sit for five minutes..
Oct 28, 2008 | Office Equipment & Supplies
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Vista Drivers
When you click on File and print - ensure the selectionis in Active sheets (this will ensure that it only prints pages with texts in excel
Aug 31, 2008 | HP OfficeJet D125xi InkJet Printer
Lexmark lv X1250 drivers
Here is driver download page from Lexmark. Select your operative system to enable download.
After downloading file run it.
Keep printer USB unplugged while installing drivers.
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
