Question about GE Lands Phones
My phone is GE 2-9450C and extension phone to my secretary, everytime my secretary transfer a call in my phone I could only talk for only 60 seconds then it cut off. How could I solve this problem?
Posted by JUN YEE on
4 Related Answers
ryancsmith
Ryan Smith
  • 62 Answers
SOURCE: Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Posted on Aug 06, 2009
Anonymous
SOURCE: WE CAN'T DIAL OTHER EXTENSIONS FROM ANY OF OUR
Try disconnecting all power for a minute and then reconnect everything.
Posted on Aug 31, 2010
Anonymous
SOURCE: I have a lucent Partner 18d telephone. I want to
That is not possible on the Partner ACS. The oONLY thing that would be close to what you want is Remote Call Forward.
As long as you have a Partner ACS release 6 or higher,
You need to set the permissions on a phone, then set that phone to forward out to teh external number. Then when calls come in, you transfer to that phone, which will forward to a cell or external number....boom, done!
Thats it though.
Posted on Oct 14, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: PANASONIC KX-T7731 PHONE I HAVE MY
I"d start by pressing the Caps Lock button on my keyboard to ask a question and use that key marked Shift to capitalize the first letter of a sentence and proper names.
Extension names are programmed in SYSTEM programming. Access to that is done from the phone connected to the first extension in your system, usually 101, with a system password. In a TA Series, it's program 604. In some others, it's program 004.
Carl
Posted on Jun 09, 2011
60 button module addition to NEC Dterm phone
sorry but only NEC technician can help you
Oct 04, 2017 | NEC Lands Phones
We have lucent phones and have know ideal of how to transfer or use intercom
To use both the transfer and the intercom it,s necessary to know the extension numbers of the phones your trying to call or transfer to. To find out what the extension number is on those extensions either press feature 00 (if the extension has a display) the extension number will be displayed on the screen, if the set doesn't have a display then you can use the intercom to call a extension that does have a display. To use the intercom press one of the intercom keys below the first two line keys and enter in the extension number of the persons phone you wish to call. To transfer a call, while talking to the caller press the Transfr key(above the hold key) then the extension number of the of the persons phone you wish to call then hang up.
Oct 14, 2010 | Lucent PARTNER18 Corded Phone
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
How do I transfer calls to someone else in the office using Norstar T7316 phone?
If your telephone doesn't have a transfer button programmed press feature *3, the button you want the transfer button to be, and enter feature 70. While on the call press the transfer button (or press feature 70) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after youpress transfer and dial the extension and they'll get the call without screening.
Sep 28, 2009 | NorStar T7316E Corded Phone
How to transfer a call
While on the call press the transfer button (above the hold key) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after you dial the extension and they'll get the call without screening.
Sep 17, 2009 | Lucent PARTNER18 Corded Phone
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Mother phone
When setting up GE phones, they are placed in the base station for ~20 seconds to register them on the system. The order that the phones are registered is the order they are allocated extension numbers for transferring calls etc.
The FIRST phone registered, becomes a mother phone, and the base station is ALWAYS a mother phone.
Jul 12, 2008 | GE 25931EE1 Phone
Transferred calls
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
May 07, 2008 | NEC Dterm DTP 32D-1 Corded Phone
All handsets cannot be used at the same time
Some of the cordless phones do not allow more than one handset to be used at the same time. Is there a transfer button on the handsets? Can you call from one handset to the other? If not the phones probably have to be used one at a time.
To get off speaker phone just push the speaker phone button again.
Jan 28, 2008 | GE 25931 Trio Cordless Phone
Lands Phones Logo
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
