Question about Yes Televison & Video
Have a brand new iRV 32 in our trailer,cannot get the menu or settings to open up from the remote or the buttons on the radio. Yes I read the manual that came with it, no help at all.
Posted by Gerilyn Stenke on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: rockband guitar wont connect
try a normal controller if the normal controller works then your gutar doesn't i would take it back to get it replaced.
Posted on Jun 02, 2008
bazzaboi
SOURCE: Remote control for teac set top box HDB842 will not work .
I had the same problem and tried new batteries with no success until I had a close look at the terminals. One of the +ve terminals was rusted (Ithink a drink spill, hastilly wiped off). After restoring this terminal everything is now OK. Hope this helps.
Posted on Jun 01, 2009
4L60B4R1UM
  • 133 Answers
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Posted on Aug 08, 2009
Anonymous
  • 20 Answers
SOURCE: Cnm mini book locked
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
hoyagese37
Posted on Jan 03, 2010
Anonymous
SOURCE: brand new c3530mfp menu reads
When you open the top (like putting a document in for scanning) there is a slider (button) on the left hand side of the glass. Just slide it from the "locked" symbol to the "unlocked" symbol.
It took me 2 hours to fix this problem, after the house cleaner turned my MFP to locked without me knowing.
Cheers,
Stefan
Posted on Jan 22, 2010
Does anybody know how to set a 32 inch Sony Bravia back to factory reset without remote
yes manually you can set press menu button then go to av setup & select factory setting from using vol+ & vol- with channel + & channel- buttons
Jun 21, 2015 | Sony Televison & Video
How do I manually change the TV stations ??
You should press the prog: button < / > to change the channels stored in each program. The number of press will depend upon which program do you wish to see. It will be best to buy a remote control for this set, as this set will not have a Menu button on its front panel, as there is only four buttons on panel, as you indicates here.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Jul 13, 2014 | Sharp Aquos LC-C3234U 32 in. LCD TV
Quasar VV-1301 cant program for cable tv channels without remote, is there a way to autosearch the cable for channels so they are able to be selected
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
Aug 18, 2011 | Quasar SP-3235 32" TV
My sharp aquos lc-42d65u is not responding to my remote control . another word my t.v does not read my remote control at all. can someone help me to fix my remote ?
U already change the remote control for brand new batteries wright?Yes.Remote controls devices are heavily depend on it CPU chip for all of it functions.Test the tv manual buttons like Power,Menu,Volume - + and Channel + - all work?Yes.The tv remote control CPU is dead that why doesn't read the tv infered laser signal at all.Try website like Remotes.com to buy an original remote for the replacement.
Apr 04, 2011 | Sharp LC42D65U 42 in. LCD HDTV
32" flat screen Protron. Remote
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
https://homenol.blogspot.com/
https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Feb 28, 2018 | Protron PLTV-32 Television
This tv automatically switches itself off after 4 hours. can I disable this feature? Thanks
Yes you can. If it's exactly 4 hours, then you need to change the "Eco" power settings as follows;
1. Press the "MENU" button on your Sony TV remote control.
2. Use the circular arrow keys on the remote to highlight the flower icon for the "Eco" settings:
3. Press the large "+" key on the remote (in the centre of the arrow keys) to open the "Eco" menu.
4. Use the DOWN arrow button to highlight "Idle TV Standby". (The current setting will be 4h)
5. Use the LEFT/RIGHT arrows to set the value to "OFF" (1h or 2h can also be set).
6. Press the "MENU" button again to close the menu and return to watching TV
Hope this helps. Please post back if you are still unable to disable this feature or need further assistance.
Regards,
BElectric
Jan 05, 2011 | Sony KDL32BX300 32 in. TV
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can't use menu function on remote control for pioneer krl-32v TV
ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
Mar 14, 2009 | Electronics - Others
Televison & Video Logo
692 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
