Is there a reset button?
Sometimes it is possible to use some hairspray. Spray the part of the belt that touches the roller. Let it get tacky before you try using it. Good luck.
You may need a new belt.
Hey Nancy... Sounds like you have broken the roller drive belt...this is not hard to fix..
Check out this link..its for the belt you need...
https://evacuumstore.com/p-7826-electrolux-epic-6500-belt.aspx?gclid=EAIaIQobChMI78fopqCb1gIVlQOGCh2__QQ9EAQYAiABEgKK1_D_BwE
SOURCE: electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
SOURCE: i have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
