Question about RCA RCR350 Remote Control
Programming Just bought a new rcr350. In the brochure titled "Code Lists" it gives "brand codes used for programmming using the brand Code Search " e.g. for Pansonic VCR the brand code is "5" but nowhere does it say where or how to use this '5'Having no luck getting our VCR - Panasonic PV4662-K to accept a code.
Posted by bbbern on
  • newman0 Dec 19, 2007
    i think i know the code for my remote, i just don't know what to do withit
Anonymous
Try this address
http://www.thompsontv.com:80/rcarc.html
Have fun.
Posted on Dec 26, 2007
STEPS TO PROGRAM T.V CODE IN UNIVERSAL REMOTE
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code
  7. You can try using these codes: RCA Codes 000,005,007,008,028, 035,037,054,069
    Hope you find this helpful.
    Thanks ,
    Dennis
Oct 22, 2011 | RCA 27V530T 27" TV
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
Sep 21, 2011 | RCA Computers & Internet
Forgot how to program their is no code button
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7732/~/programming-the-rca-rcr350-universal-remote-control should give you your answer. Access to code lists and product manual are also provided at the bottom of the web page.
Feb 22, 2011 | RCA RCR350 Remote Control
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
  • TV-000
  • VCR-000
  • Cable Box-000
Sep 07, 2009 | RCA Universal Remote Control
Need to program a new remote for RCA TV
  • TV-000
  • VCR-000
  • Cable Box-000
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
Aug 24, 2009 | RCA Universal Remote Control
Need codes
Unit does not have a manual, but I did find this -
Let me know if this works, and if not, I'll keep looking.
Feb 01, 2009 | JVC DR-MV100B DVD Recorder/VCR
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 24, 2008 | RCA Universal Remote Control
Code for RCA remode
This is all I could find.
Jun 21, 2008 | RCA Universal Remote Control
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
RCA RCR350 Remote Control Logo
91 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
