Question about Hotpoint Washing Machines
Hotpoint AQ9D692I washing machine briefly displayed F05 error code. Now appears to work as normal except won't pump out. no power to pump
Chris Huff
    Top Expert:
  • Hotpoint Master
  • 6,289 Answers
If power is not getting to pump, control Board most likely sends power to it.
Posted on Sep 09, 2017
richie46
    Top Expert:
  • Hotpoint Master
  • 12,962 Answers
Isn't the pump belt driven by the motor of unit? Is this connection secure? Slipping?
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Error codes
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Posted on Feb 02, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Posted on Jan 31, 2010
rickead1
Rick Ead
  • 1998 Answers
SOURCE: Hotpoint Ultima wash machine has error code F05
hello you have a jammed pressure switch on full it says so if removed the blockage have u tired replacing the pressure siwtch. You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Obviously the machine will need isolating first and the switch will need removing from the machine. it depends how handy you are if you can change brakes in a car this will be an easy task to replace hope this helps please remember to rank how this helps you and if i can help in any other way please write me back have a great day
rickead1
Posted on Aug 17, 2010
Testimonial: "Thank you for the quick response, since posting I have done a little more research and believe you are 100% correct. I"
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
