Question about Hitachi Televison & Video
Its a hitachi ultravission model # 42 hds 69
SOURCE: no pic hitachi 42 hds69 3 blinking lights on back
http://www.hitachi.ca/supportingdocs/en/forhome/plasma_tvs/42HDS69.pdf
Here is the user manual. You may need to call Hitachi.
Posted on Nov 28, 2008
SOURCE: Can a HDS 5 Lowrance
Hi, well I am sorry to be the bearer of bad news but those two are NOT interchangeable sorry. The "Drive Current & Voltage" for the Transducer are not the same at all, in fact i don't even think that the "pin outs" are the same? but cannot remember off hand? Unless specifically indicated by the manufacturer, one cannot usually swap transducers among instruments, if one does/did do so, well indeed the transducer maybe damaged and or the output of the sounder maybe damaged as well?
These manufacturers actually make it so that none of their equipment is interchangeable, as they wish to maximize the profits you see, and if one could just swap things among models etc, then "They" would, in their mind anyway "loose out"
So you will simply have to cut a new hole and mount for you new transducer. make sure you mount it in the manufacturers recommended place, the Bow is fine, although I often recommend that it be central to the craft, but, sometimes this isn't possible for varying reasons.
Sometimes if one must retro-fit a new transducer to an existing but different size etc site, then, it is best to "Fill" the old mounting hole(s) with a suitable material, and then re-drill and re-mount it all again.
Posted on Jul 09, 2011
SOURCE: I have hitachi plasma 42 HDS 69 tv it's shows " No sync signal" so how to fix that at home?
Hiya!
If I understand your question, it seems that you'll need to go into the TVs 'input selection' part of the menu and try another input until you get a signal
Please let me know how it goes
Posted on Nov 20, 2016
SOURCE: Is it ok to use the power cord from my monitor to power my hitachi 42 hds 69
If fits and voltages are the same, why not.
Posted on Sep 08, 2017
SOURCE: Is it ok to use the power cord from my monitor to power my hitachi 42 hds 69 tv
if the connections are the same as would be the correct voltage ===yes
a power cord is just a power cord and carries electricity regardless of the voltage
however if the connection at the power outlet in the wall is different then that suggest that the cable in questions is connecting different voltages to the unit than is allowed
