Horns not working,original relay 43yrs old !
You hear clicking at horns, and not the relay? Maybe the horns went bad, or maybe you need to check and clean the connections there.
Don\'t know why the cab light went dim, unless the horn wire was trying to make contact?
Yes, TJ, the horn wire should be hot. You are grounding that hot wire when you press for the horn. That hot wire comes from the coil side of the horn relay. Press for horn, it grounds the coil side of relay, and the relay can pass power to the horns.
Now back to the clicking no-honker horns: power gets to the horns when relay is energized, and there has to be a good ground for horns to work. I don\'t know if your horns are case grounded or a wire from horns goes to ground, but check the ground there. If case grounded, pull horns off and clean the ground. Also might try a known good horn. Keep at it, sounds like you are almost there.
