Question about Pan Photography
The screen on my pan digital frame is not bright
  • Pan Master
  • 6,229 Answers
Look in the manual for brightness control
Posted on Sep 08, 2017
Anonymous
SOURCE: pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Posted on Jan 26, 2010
How to remove battery digital picture frame
I believe the only battery you have to replace is in the Remote Control ? The picture frame itself does not have a battery .. only the A/C connection.
To Install or Replace the Remote Control Battery :
1. Hold the Remote Control with the control buttons facing downward.
2. While pressing down on the ridged area of the battery cover, pull the tray out.
3. Place a "CR2025" Lithium battery on the tray with the positive "+" end facing toward you.
4. Close the tray.
Hope this helps.
May 03, 2014 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
Screen is very dark, cannot see pictures! And can't even see the menu to try to fix it! help!
Attempt by going in a complete dark room with no lights, and see if you can see the screen at all to atempt to access the menu, sounds like that the Brightness or Contrast was adjusted too far. If that doesn't work, reccomend trying to take to place of purchase and exchange for new one.
Miller Photography
www.millerphoto.ca
Mar 18, 2010 | Coby DP-888 8-Inch Digital Photo Frame...
Pandigital pan 70-0 progressively got darker. now you can bearly see picture
Hello. your frame has a dial on the side which makes it brighter or darker. Just turn the dial to adjust it. Regards, Joe
Feb 17, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Screen not readable in bright sunlight.
This is a problem with digital cameras with LCDs. You can make things better by upping the brightness of the screen - this will consume more power though.
Go into the menu (middle button at the back), into 'setup', and then look for 'LCD brightness'.
Apr 17, 2009 | Kodak EasyShare V1073 Digital Camera
Can't see picture in frame when taking outside pictures
My pandigital photo frame is frozen on the sytem start screen
Mine does this when the power cord shorts itself out. For a whileI could fix it by simply untwisting the cord close to the plug, but eventually I had to cut and splice the cord to keep the lines separate (think a bunch of electrical tape. It works fine now that the cord isn't shorting out. Hope this helps!
Feb 02, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Customer service to help me to use quantaray by sunpak
I have a quantaray 15" photo frame and I cannot get the screen bright enuf to see the image.
Dec 31, 2008 | Quantaray 7-Inch Digital Picture Frame -...
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Pan digital 7 frame screen goes white
Good luck.
Sep 09, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Photography Logo
388 people viewed this question
Top Pan Photography Experts
Ekse
Marvin
Marvin
Are you a Pan Photography Expert? Answer questions, earn points and help others
