Question about Generac Electrical Supplies
On a Generac Power House 5500 watt gerenerator, how would one reconnect the fuel filter/fuel cutoff to the fuel tank?
Posted by Erwin Renwick on
toddgilbert
    Top Expert:
  • 6,360 Answers
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link. Best Manuals
Posted on Sep 08, 2017
4 Related Answers
Anonymous
SOURCE: dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Posted on Aug 09, 2009
lnbn1975
  • 204 Answers
SOURCE: my fuel lines became rotten and i'm not sure how
A bit more time consuming and requires patience more than skill on this task.
First, only take off 1 of the fuel lines at a time. That way you can make sure you put the right hose on the right fitting.
Let's start with the line with the filter. Take the line off the carburetor. Cut a bit of it and go to a mower repair shop to get your new fuel line. Get about 2 feet. That's about double what you need, but will probably waste some in the process. When you get the new line, cut a sharp point at 1 end. Get a needle nose pliers and reach into your fuel tank and pull out the filter and the rest of the fuel line. Get a fairly fine wire, wrap it around the pointed end of the new fuel line. Snake the wire into the tank and out the small hole. This will help you pull the new hose into the tank and out the hole. This might take a bit of time. When you get the new hose out, square off the end and push it on the carb fitting. Cut the hose where it enters the tank and slip your fuel filter on and drop into the tank. 1 down and 1 to go.
Host #2 can be put into the tank the same as #1, or you can try to push it in from the top. May work with a little lubrication. Hook #2 up to the carb.
This should get you up and running.
Posted on Oct 26, 2009
mjc13
  • 3 Answers
SOURCE: Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Posted on May 14, 2010
SOURCE: VX-5500 LowBand change power to 20 or 50 watt to suit power amplifier.
The channels can be programmed for either low or high power on a per channel basis. Perhaps I do not understand what you are doing? It would be easy to program each channel to 20 watts. I would take the high power and turn it down since the low power setting from the factory is usually under 20 watts.
Posted on Sep 24, 2012
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
Mar 04, 2013 | Pramac Diesel Generator 5500 Surge Watts,...
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
Generac home generator does not start. It starts alittle bit but then dies. Maybe runs for 4-6 seconds
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Feb 05, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
43 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
JOHN LAPIER
Bill Johnson
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
