SOURCE: conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
SOURCE: ERR comes up when standing on scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: Scales are getting a Err 1 message, installed new batteries
My scale was fine the other day. I weighed myself earlier in the day. I tried to weigh myself later in the day and the scale started reading ERR1. I called Taylor and they had me try to "reset" the scale twice. It did not work.
The steps for resetting it are:
Turn the scale over
Remove the batteries for at least 10 seconds
With the scale on it's side (even though you aren't supposed to put the scale on it's side, carefully insert the batteries and put the back on the scale
Slowly return the scale to a flat hard surface
Step on the scale after about 10 seconds of it being back in position
If the scale still jumps with crazy numbers and reads ERR1 try to reset the scale again being very careful when the scale is on it's side
If this does not correct the problem then the scale will need to be returned to the manufacturer, to the address on the label on the bottom of the scale
I was told you could put the scale in any box and ship it to them the cheapest way possible but be sure to keep the batteries with you
If you are still under the year warranty they will send you out a new scale in 4-6 weeks
I was not happy that my scale was purchased on 11/14/09 and it died on 02/12/10. Luckily I knew where my receipt was. I pulled it out and noticed 02/12/10 was the last date to make returns to Target for that transaction. I was able to go and return my scale to the store because it was in the 90-day window that I had purchased it.
I was told that the reason the scale was doing this was either an delayed electrical interference that may have occurred during. The only other reason I was given was an OVERLOAD. Well, I seriously doubt an overload was my issue. First of all I was the only person at home that day so nobody else stood on the scale. I had used it earlier in the day and it was accurate. I am 5'6" and 139 lbs. so I seriously doubt it was OVERLOAD unless someone isn't telling me something and I need to lose some serious weight.
Anyway, I hope this helps. I wasted a lot of time trying to figure it out that day. Now I have my new receipt and if this happens again I will go get my new scale just as I did this time. I thought a 4-6 week wait for a replacement scale was insane. Kudos to Target for taking the scale back without a box or instructions on the last day I was able to make a return.
