SOURCE: Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E key.you can go through all 20 channels this way.
SOURCE: need codes to program my police scanner
here is a few sites that can head you in the right direction.www.radio reference.com,www.scannermaster.com,www.bearcat1.com.hope these help
SOURCE: programming bc147xlt uniden scanner
to program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
