SOURCE: I have a sentient CCTV Hard drive recorder. Was
Unfortunately it is past DIY stage. Consult a service center.
Cheers
TeaCii
If you own website, add
live support almost free
Real
security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
SOURCE: cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
Posted on Jun 14, 2010
SOURCE: Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
Posted on Oct 17, 2010
SOURCE: just installed a sentient 250gb
By default it goes to VGA port out of the DVR.
So you could hook up a pc monitor to it and use that. Once logged in you can change to tv out via the desktop menus.
It is also possible to hold down a button on the DVR (cannot remember which one sorry) at DVR power up to switch it to use tv out instead of vga.
Posted on Jan 26, 2011
SOURCE: I have a Sentient CCTV System and now all the
Look for Totally tight cable connections. A break in the grounding causes the interference, usually. It only takes a slight loose connection to have issues.
Posted on Jul 10, 2011
