Question about Hisense Televison & Video
The set will have some manual controls on front, side, or backside. But they are not very comprehensive usually.
Posted on Sep 06, 2017
SOURCE: hisense tv wont turn on
follow the power cord inside the set and to begin with look at the fuse which the cord goes to--also inspect to see if puffed up caps in the power supply----see attached photo
Posted on Apr 29, 2012
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Posted on Oct 17, 2008
SOURCE: hisense tv code needed
Even though this problem is a year old, I thought that I would share my solution for Remote codes for a Verizon FIOS.
I tried asking Verizon, and Hisense for a code that would work as the published codes did not work to program my Verizon remote. No answer from either.
I accidently discovered that the codes listed for LG worked, in fact the first code listed worked. I surmise that Hisense uses the same codes as LG.
If you are at wit's end then try the LG codes.
By the way. I tried stepping through all codes several times but no success with the Verizon instructions. The fact that the LG codes worked, indicates that the Verizon solution is wrong.
Posted on Jan 19, 2012
