Question about Lexmark Office Equipment & Supplies
MY PRINTER LEXMARK s605 IS NOT COMMUNICATING WITH MY LAPTOP. HAVE TRIED UNPLUGGING AND PLUGGING IN AGAIN BUT STILL NOT PRINTING.
5 Related Answers
Anonymous
SOURCE: computer not communicating with printer
Please, what am I missing??
Posted on Feb 19, 2008
Anonymous
SOURCE: ink system failure erorr 0xc18a0306
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Jun 19, 2008
Anonymous
SOURCE: Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Posted on Jul 07, 2008
Anonymous
  • 144 Answers
SOURCE: COMMUNICATION NOT AVAILABLE LEXMARK X1150
Hi
This kind of issue might occur due to many reasons, like:
the previous installation files creating a glitch for new software.
PORT settings
Resolution:
goto devicemanager by following:
start->run->devmgmt.msc (type in the box)
check if you have printers with exclamation mark or any special symbol showing a problem with the device.
try updating the drivers,
a more feasible solution could be removing the usb composite device entries from the tree under usb section but this should be done only by a skilled technician.
Thanks & Regards,
Amit Verma
HP AIO printers support
more than 3 years of AIO printer troubleshooting expertise.
Posted on May 11, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x5250 flashing green power light
    The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
    1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
    2. Open the printer cover and remove both the cartridges.
    3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
    4. Close the printer cover.
    5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
    6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check the light status.
    8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
    9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
    10. Load some paper. Try to print a document again to verify that the problem is fixed.
    Posted on Jan 29, 2012
    Lexmart s605 printing grey and black squares
    It sounds like a problem with the printhead. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. You can find the contact details at support.lexmark.com.
    If it's already out of warranty, you can purchase a printhead here: http://bit.ly/IZYhWo
    Dec 03, 2012 | Lexmark "interact s605 wireless all-in-one...
    There is a problem communicating with the printer
    Please download the firmware update from the Lexmark website www.lexmark .com and install the patch http://bit.ly/pWGkeE after updating.
    Jul 12, 2012 | Lexmark Interact S605 All-in-One Color...
    Lexmark 605 printer not downloadable to toshiba laptop
    It would help if you placed the Operating System of your computer. Anyway, you can find all of the drivers for your Lexmark S605 at www.lexmark.com.
    Make sure to indicate if it's a 32bit or 64bit. Most probably you have a 64bit system.
    Apr 01, 2012 | Lexmark Interact S605 All-in-One Color...
    Lexmark interact S605 has document blocking any further printing and even when I have unblocked previously the next document still blocks
    If you're having problem with print jobs getting stuck in the print queue, it could be due to your computer's print spooler service not running. Try the steps below to fix the problem:
    1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
    2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
    3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
    Feb 09, 2012 | Lexmark Interact S605 All-in-One Color...
    Lexmark Z2000 doesn't communicate with computer
    Sounds like it is stuck in "Power Save" mode. Try unplugging the power cord and plugging it back in again. That usually fixes this one...
    May 06, 2009 | Office Equipment & Supplies
    Lexmark X6150 Inkjet - Problems Communicating with Printer
    For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
    Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
    check the cable it may be bad. Its not always visable. if the usb wire is plugged in and it doesnt see it under printers then it may be the cause
    Apr 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Printer and computer not communicating
    sorry my printer is lexmark 1200 series, tried restarting,unplugging usb, power supply to printer but keeps just sayin printer not communicating with computer
    Feb 09, 2008 | Lexmark All-in-One Printer with PictBridge
    37 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    CheckitRight
    CheckitRight
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
