Question about Bosch Televison & Video
Anyone got a circuit diagram for a Bosch wf02465gb washing machine?
Version is /01, fd8309 600788. Main circuit components would be fine but preference of control board was included. Thanks
Posted by Alex on
richie46
    Top Expert:
  • Bosch Master
  • 12,962 Answers
Google for it or go to this website which often has appliance schematics Search Over 2 1 Million Appliance Parts
Posted on Sep 06, 2017
5 Related Answers
Anonymous
SOURCE: Problems with washing machine cycles
does it heat up? if not the element has gone and needs replacing. try it out on a cold 30 wash to see if it goes through if so element probs.
Posted on Jun 01, 2007
mcpcis
SOURCE: BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Posted on May 23, 2008
Anonymous
  • 106 Answers
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
Anonymous
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
Anonymous
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
The plug of my Bosch Maxx7 melted and also the lead. I put a new plug etc on and the spinn light keep flashing and tried to reset the machine but it wont come on.
Most likely, the main control board of the washing machine was damaged by the power surge that melted the plug. Additional wiring damage may have also occurred. The damaged electrical parts will have to be replaced.
Please add a comment with the model number of your washer if you'd like a parts diagram and price list for your machine. The parts diagram for one Bosch Maxx7 model, WAE28490GB,
is available here: http://www.bosch-home.co.uk/customer-service/care-protection-and-parts/WAE28490GB/01#/TabsTogglebox=spare-section-3/ . See diagram 1/5.
Your homeowner's insurance may pay for the damage, under some circumstances. It isn't covered by the Bosch warranty.
How do I reset washing machine Ariston AR7F105 , error code F-01.
F01 - Main modul, triac on board damaged or components feedback fault
  • Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Dado
Hi, Can someone kindly assist with operational manual for Bosch washing metchen WFR 2850/01,and how to change the launguage
this link will take you to the Bosch home page you'll find a full user manual for your machine there http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Bosch exxcel 1200 express
As the control board failed it could have let too much power reach any of the other components in the machine. Any electronic components could now be damaged. The new controller could now be damaged by power from the other parts. You could carefully replace them all one by one until it works, but this will be expensive. Buy a used machine of the same make and model (search Ebay) and swap all its electronics over in one go. Or replace the machine.
2helpful
My bosch washing machine Maxx classic wont turn on
Please check the main power from the power outlet the mains plug to the controller unit. If there is power then check within for the fuse, if fuse is intact then check for burnt items, if so the board could be damaged and needs a replacement. In most cases if the fuse has blown it is possible that the board has failed and so changing the damaged component could be difficult as the board is immersed in epoxy.
There is no power going through my Bosch 1200 washing machine. I have changed the fuse but nothing. The powe supply is fine. I have moved on Saturday and the machine was working fine in the morning
In such cases what is needed is to remove the power plug and using a multimeter you must check the continuity of the power to the main controller board. If so connect and check the mains voltage to the board. If the boarrd does not respond you need to remove and replace unless you are an expert to check for component level failure.
click this link for tips : Control board
Machine worked fine last night. This morning spin not working. Have tested it empty, put it in spin program, a funny clicking noise and then nothing, then after a while indicator shows 01 - ie. finished!...
n most washers the F01 error indicates an control board problem. It is like an internal program error.
A power glitch can cause the problem.
One of the things to try is to enter and run a diagnostic cycle, or unplug the machine for 30 mins.
4helpful
2answers
Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Televison & Video Logo
Top Bosch Televison & Video Experts
Steve Pack
Steve Pack
Larry
Are you a Bosch Televison and Video Expert? Answer questions, earn points and help others
