Question about Light Office Equipment & Supplies
My printer gc420t give me red light error after one label print plz tell me how to solve this..i bougth new printer
    Top Expert:
  • Light Master
  • 12,962 Answers
Original printer may need to have the software reset or it may have a physical issue in the drive causing the printer error.
Posted on Sep 06, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: hp laser jet 1020
My friend had the same problem. A small sliver of paper was blocking one of the contacts where the cartridge connects with the printer. Removed it and voila!
Posted on Dec 10, 2007
Desmond Pillay
  • 40 Answers
SOURCE: Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Posted on Jan 24, 2008
Anonymous
SOURCE: In my printer power is on and red light will appears
I have to install this printer in xp professional o.s.
than what can i do now
Posted on Mar 22, 2009
Anonymous
SOURCE: R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Posted on Nov 19, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: HL-5370DW laser printer will not print labels.
It probably wants you to insert label sheet thru the envelope slot in the front, using the cassette peels the labels off of the sheet. If there is nothing in the front slot when you select labels it will show an error.
Posted on Dec 29, 2009
I have zebra gc420t label printing upside down ... how do we correct?
Hi, you need to set from driver or from software driver properties.
a) If you are using direct printing from a system, then(In windows), go to printer driver properties (general and advanced tabs) and find the orientation feature. If you don't have an advanced driver with advanced features, then go to www.nicelabel.cl and download it for free, selecting your printer model and brand.
b) If you have a software, then you should be able to see a button in the top that says "printer properties". You can normally access the driver properties from there, then you follow the instructions from a). The only problem about that is that it is normaly for testing properties, but not necesarily will solve your problem forever...
You can play winner by following a) step.
Jun 18, 2014 | Zebra TLP 2824 Printer
Gc420t red light
Call for tech support.
Apr 16, 2014 | Office Equipment & Supplies
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
R230 Epson Printer
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Mar 28, 2008 | Zebra LP 2844 Thermal Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Printing Problems to my new Copier
TURN ON APPLE TALK IN NETWORK SETTINGS OF PRINTER THEN ADD PRINTER ON YOU COMPUTER.IT SHOULD FIND IT ON THE NETWORK AND PESTO YOU CAN PRINT
Jun 26, 2007 | Toshiba Estudio 200L Copier
1,166 people viewed this question
Top Light Office Equipment & Supplies Experts
Marvin
Marvin
Copy-Tech
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
