Question about Electrical Supplies
Replacing input jack on a behringer guitar amp model GMX 210?
Its a small board part # QO5-21203-808290 WITH 1 RED WIRE AND 3 BLACK WIRES COMBINED IN A SINGLE PLUG CONNECTING TO THE MAIN BOARD
Posted by Charles Otto on
Drum Slinger
Take the effects loop jack, its 3 wires, and small white female connector out if the back of the amp, install it in the front, might need to cut the black wire farthest from the red wire for ground, and plug connector into white 4 pin box right next to input jack so that the red wire is closest to input jack. You only need 2 of the 4 pins to make circuit, 1st and 2nd closest to input jack. Might need to tweak the wire configuration in the white connector a bit but it worked for me, and without loosing built-in effects.
Posted on Nov 06, 2020
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Behringer Vintiger GM110 guitar amplifier Output pcb board
You should be able to get a diagram from the company itself and the circuit board can either be purchased from the manufacturer itself or they can tell you who to call.
Here is the manufacturer's number
BEHRINGER USA beusa_t.jpgBEHRINGER USA Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
you can also try their online support at
http://www.behringer.com/05_support/webform_support.cfm?lang=ENG
but I would just call them, it would be much easier
Let me know if you need any further help or if they couldn't help you and I will let you know who else might have what you need.
good luck
Posted on May 23, 2008
ABRsvcs
  • 4234 Answers
SOURCE: PEAVEY TRANSTUBE AUDITION 110. PLUG
There should be an 8 pin IC close to the input jack that will be marked 4558 or 4560. This is an Op-amp Ic that is the most likely cause of the problem. Replace that IC and report the results here.
Dan
Posted on May 28, 2008
fs8228
  • 127 Answers
SOURCE: Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Posted on Jan 06, 2010
j_warenzek
  • 49 Answers
SOURCE: Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Posted on Jan 16, 2010
Anonymous
  • 351 Answers
SOURCE: trying to convert my dryer from 3 prong to 4 is
Hi .. I am posting a sketch of the 3 wire and 4 wire connections .. if you have any questions please get back to me ..
Posted on Jun 19, 2010
How do I replace cord jack on a Peavey bass guitar?
You'll need needle nose pliers, small phillips head screwdriver, soldering iron, electronics-grade solder, socket screwdriver or 1/4" wrench, black electrical tape. Purchase necessary replacement jack. Remove plastic electronics cover plate, located on the back of the body, behind control knobs. This will expose the electronics cavity. Locate existing jack and its wire connections inside the exposed cavity. Remove any electrical tape covering the jack connections. Using a hot soldering iron, touch each of the two soldered input jack connections, one at a time, just until the soldered connection melts. Then, disconnect the associated wires (taking note of which wire connects where!). Once disconnected, loosen and remove the nut on the outer part of the jack that holds it onto the guitar body. Remove the old jack. Insert the new jack (with the nut removed) into the existing hole, from inside the electronics cavity and tighten it in place, on the outside of the guitar body, with the nut. Re-attach the wires to the new jack, by using needle nose pliers to wrap them tightly around the correct posts. Touch the hot soldering iron to each post and apply a small amount of solder to the post as it's being heated. Once the molten solder runs over the connection and looks shiny, remove the tip of the soldering gun. This process takes only 2 to 3 seconds. Let the connections cool for a few seconds. To insulate, wrap connections with black electrical tape. Replace cover plate.
Apr 27, 2014 | Peavey Music
Wiring help for realistic 5 band equalizer cat.no.12-1963 don't know year or model of unit it has no wiring label on it. has 3 gray wires, 3white wires,3 green wires, one black wire,one brown wire....
the 5 thinner cables goes to positive lead of each speaker from the radio (input to amp) the red one to battery.You will not use the negative led for the speakers from the radio. The remaining coarse ones goes to the speakers (each pair same color to a speaker) and the red one feed radio positive led. Black is ground.
Jul 03, 2011 | Car Audio & Video
My deville has just stopped producing any sound what soever. All the tubes glow and the red power light is on but no sound. I have tapped the sides of all the tubes and they all register a sound except the...
The first thing i would do is not leave it on in this way for too long. You could blow out a very expensive Transformer if its a faulty speaker. The worst thing you could do to a TUBE amp is run it without a speaker . I would test the speaker first. Just remove the wires going to it. And connect the speaker to either a car stereo or house system at low volume very low. And see what you get. if it works ? Good! Now check your guitar chord/wire. Try different ones try different guitars. If that doesn't work . Look into the input jack on the instrument input hack on the amp.. They do come loose off the board.Either get a new input jack or resolder the old one. if you only have one guitar look at the guitar output jack. Loose wiring on the guitar could cause this also. Dirty In and out put jacks could cause this. A pencil with Very fine sand paper wrapped around it will clean a dirty input/output jack. Try these things. Just remember poking around your amp is Dangerous. The electrical components hold a charge even unplugged that can kill you. No joke..
Dec 26, 2010 | Fender Hot Rod Deluxe Guitar Combo...
In the Intermatic ST01C, what is the function of the red wire in a two-switch set-up, which [after the second switch] goes to the same place as the [timer-switched] blue wire?
ST01C is battery operated timer with red, blue, black & green wire.
Red wire is used when replacing 3-way switch (for ex: light switch at each end of hall)
Red wire is capped off when replacing single-pole switch.
If red and black wires are combined, lights will blink.
If red and blue wires are combined, timer reverses ON-OFF function (just like a 3-way switch reverses).
See wiring diagrams for ST01C
http://waterheatertimer.org/ST01C-program.html#ST01C
Nov 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
My Behringer gx212 ultratwin amplifier started to lose volume last night at band practice and then I smelled buring wiring. I think I lost or am in the process of losing the amp transformer. I think the...
Hi I just recently purchased a Behringer GMX 212 and had similar volume dropout on the clean channel only Channel 2 works better and has more punch in clean mode.I went to the shop where I purchased it with a 7 day warranty from some indian dude here in Nadi Fiji, and there was another GMX 212on the floor so I decided to try it out. This was a new amp. I plugged into the clean channel and turned it up full volume on guitar and amp adn heard the volume drop of in the amp in almost a curve and then the whole amp just cut out. We unplugged and waited, turned the amp off, and then on and stil no sound. We then tried the guitar and cord in another amp. The other amp was fine. Can you solve this problem.......my gut feeling is this happens a lot to Behringer amps.
May 08, 2009 | Audio Players & Recorders
PEAVEY TRANSTUBE AUDITION 110. PLUG UNIT IN POWERS UP . SITS THERE AND HUMS LOUDLY. SPEAKER WORKS. plug guitar in can hear it faintly, push lead chanel button in , hum gets super loud. HUM IS IN PROPORTION...
Dan
May 27, 2008 | Audio Players & Recorders
Electrical Supplies Logo
443 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
