Question about Amana Refrigerators
I can't find the reset button for my Amana fridge
Posted by Petty Nation on
  • 1 more comment
  • Petty Nation
    Petty Nation Sep 06, 2017
    All I know is that the fridge is silent, thays how I know it's not running. The light is on but the fridge and freezer is not running at all.
  • Petty Nation
    I'll have to talk to the property manager tomorrow so they can see if I need another one.
  • richie46 Sep 06, 2017
    In all likelihood the hard start relay/capacitor needs to be replaced so compressor will run.
richie46
    Top Expert:
  • Amana Master
  • 12,962 Answers
Contact manufacturer for its location,if any.
Posted on Sep 06, 2017
Amana refrigerator Light and refrigerator/freezer top freezer model are both off. Is there a reset button? Both were fine last night.
if everything is out even the lights check the plug and make sure the fuse or breaker isn't popped,unplug the fridge and plug a lamp or something in there to check power,i've seen fridges on a gfi plug so check that too,but sounds like no power to fridge.next time send the full model number off of the machine,
Feb 04, 2018 | Amana Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
My model AFI2538AEW fridge control panel is stuck and I cannot select anything on it.
Can you unplug and replug it back in to reset compter? It might be easier to go to your circuit breaker box, vs pulling fridge out, and turn off fridge from there. That will cause it to reset. Here is the manual for it.
http://kitchen.manualsonline.com/manuals/mfg/amana/afi2538aew.html
Nov 15, 2016 | Refrigerators
The other morning I woke up to a fridge with no power. I'm not sure if the problem is the fridge or my oulet. The only reason I do not know for sure is that I cannot get my fridge out of where it is. So I...
The plug will have to be gotten to in order to test the refrigerator properly. Do check the right ampage fuse is fitted 13A in the UK.
There is no reset button on your model.
Jan 12, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
I cant get my refrigerator unlocked
Hi: I don't know if you have the manual, but you have to hold down the lock button down for several seconds to release it. That how it works. I hope this helps and you don't need service. As a last resort unplug the fridge for an hour ( don't open it in the interim) then plug it back in and see if it resets. I hope this helps, Jeff
May 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Hi, I have the amana drb1901cc bottom freezer. I think the compressor is out, but how do I check it?????? When plugged in the lites come on but no fans or compressor is there a reset button or something I...
hi thanks for the question i don't think you have a compressor problem i think the fridge is stuck in the defrost cycle you need a defrost timer thanks the appliance doc
Sep 27, 2008 | Amana Refrigerators
Refrigerators Logo
179 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
