Question about Amana Refrigerators
Where is the reset button for my Amana refrigerator? The fridge and freezer is not on at all, but the light is on.
Posted by Petty Nation on
richie46
    Top Expert:
  • Amana Master
  • 12,962 Answers
Did U check to see if compressor is running?
Posted on Sep 06, 2017
5 Related Answers
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Anonymous
  • 121 Answers
SOURCE: warm fridge
check the fan in the frezer and check the defrost
Posted on Nov 29, 2008
Anonymous
SOURCE: my amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Posted on Jan 15, 2009
Anonymous
  • 221 Answers
SOURCE: Amana af12538aes Refigerator No lights, ice, water
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Posted on Jan 19, 2009
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
Amana refrigerator Light and refrigerator/freezer top freezer model are both off. Is there a reset button? Both were fine last night.
if everything is out even the lights check the plug and make sure the fuse or breaker isn't popped,unplug the fridge and plug a lamp or something in there to check power,i've seen fridges on a gfi plug so check that too,but sounds like no power to fridge.next time send the full model number off of the machine,
Feb 04, 2018 | Amana Refrigerators
Amana side by side fridge makes a groaning noise when freezer is shut, no ice buildup nothing, just groans when light button is pushed
When light goes out, fan starts inside. Groaning sounds like the fan is hitting on something or has a dry bearing. Spray with wd40 on the shaft
May 01, 2012 | Amana Refrigerators
Fridge and bottom freezer not cooling. Light on when door opened. Is there a reset switch/button? It is an Amana
There is not a reset switch/button. Do you hear any noise at all, fans or clicking noises?
Jan 11, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge is not cold but the light will turn on...
Hi, Has it been 30 minutes since you turned it back on? It might be in defrost cycle. Please let me know I can assist you further.
Vic
May 30, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana bottom freezer...
i have the same problem . The Store where we pruchased it (with a five yr extended warranty I might add) said try unplugging it and reset the computor. We have also replaced the compressor already. I think we have a lemon. Frustrated.
Apr 26, 2008 | Amana ABB1921DE Bottom Freezer...
Amana ARB2217C Fridge
its under the light bulb assembly in the frigidare compartment
Dec 29, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
689 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
