Air Purifiers Logo
Question about Sharper Image Air Purifiers
Sharper Image convection oven won't work after using about a year. We love it, but this is our second one that stopped working. Is the halogen light the issue. No power at all to the unit...
Posted by Snap Troeschel on
5 Related Answers
ginko
Ginko
  • 19396 Answers
SOURCE: blinking blue lights
Here is the Ionic Breeze GP SI730 Air Purifier service manual:
http://www.fixya.com/support/p94230-sharper_image_ionic_breeze_gp_si730_air/manual-17755
hope it can help you
cheers
Posted on Feb 16, 2008
Bob Duker
  • 96 Answers
SOURCE: The light on my S1719
Unfortunately, I can't find that information, as the company is currently in Chapter 11 and has sold off all rights to it's products as of June. From my experience though, when the light begins to flash, it is supposed to be replaced. At least I had to replace one that way while under warranty.
Posted on Jul 11, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Posted on Jul 12, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Sharper Image Ionic Breeze Gp Silent Air Purifier
Ionic Breeze machines are no longer being supported. Sharper Image recalled the product several months ago after it was proven by Consumer Reports and the EPA that the product wasn't cleaning the air and can be harmful to use. Sharper Image took legal action and lost.
The Consumer Product Safety Comission is going to make a decision on all ionizers by the end of the year. It's looking like all ionizers will no longer be sold in the U.S. regardless of who makes them.
Posted on Aug 18, 2008
Anonymous
  • 3 Answers
SOURCE: Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Posted on Nov 26, 2008
How do i replace halogan light
https://www.youtube.com/watch?v=gTSNUQmSzTw
1helpful
2answers
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
4helpful
2answers
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
Unit does not work even tho blue light shows its on
The bad news is that Sharper Image filed for bankruptcy this year closing all their stores. There unable to honor the warranties on the units and even recalled all Ionic Breeze units.
Here is a link as to what happened to the company:
http://www.aircleaners.com/sharperimage.phtml
You can still get parts for Ionic Breeze at this link:
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKfhotf9_JYCFRxNagodHR10Yg
It could just need some new plates for it.
Sharper image quadra-professional series stopped working
Sharper Image has discontinued the product after Consumer Reports ran a test on ionizers.  Sharper Image couldn't prove they cleaned the air and had to pay all legal fees forcing the company into Chapter 11.  They recalled the items as well but couldn't honor the checks.
EPA data has proven that in some environments they can be harmful to use.
Consumer Products Safety Commission is going to issue a report by the end of the year.  It's possible that sales of all ionizers will be gone by next year.
Model#s1637
Sharper Image has recalled the units after Consumer Reports reported that they didn't work. They went to court Sharper Image couldn't prove that they did work, was ordered to pay all the legal bills, and filed for Chapter 11.
Consumer Products Safety Commission is going to issue a report at the end of the year on all ionizers. Their decision will effect sales of all ionizers in the U.S. With EPA data indicating that not only do they work but there harmful to use, it's beginning to look like the product is going to vanish.
2answers
SHARPER IMAGE AIR CLEANER HAS STOPPED WORKING, NO BREEZE COMING FROM UNIT AND BLADES ARE NEVER DIRTY. THE "ON" LIGHT IS ON.
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
