Question about Lexmark Office Equipment & Supplies
Lexmark c792 how to replace itb reset fuse
Posted by Robert Moore on
The printing is blurred, how can I correct?
# Do the color calibration..chk
# Take diagnoses page printout(menu print out).. ckh 'L' shaped corner images (as shown in fig), if they are not properly aligned, could be ITB faulty..Replace ITB..
For tech guys:
This activity requires lot of patience & experience..
* use gloves, don't use sharp tools, don't tough ITB belt, don't expose ITB in daylight longer..
ITB alienation sensor dirty, remove ITB, locate sensor clean clean it gently with swab.. re-fix back, calibrate the unit, chk...
May 02, 2014 | HP CP3525N Color LaserJet Printer
What is one difference between ITB and electrostatic transfer belf(ETB) technology
ITB = Intermediate Transfer Belt Where the total print image is transferred to the belt then to the paper before being fused. ETB = Electrostatic Transfer Belt where the print image is transferred directly to the paper and the toner never touches the belt.
Nov 05, 2012 | Office Equipment & Supplies
59.FO Error
The primary transfer-alienation motor has
experienced an error.
1. Check to ensure the ITB(intermediate
transfer belt) is installed
correctly.
2. Run a sensor test to verify that the
primary transfer disengagement roller is
functioning. If not replace the sensor
(SR17).
3. Run the primary transfer drive test in
actuator drive mode. If not functioning
replace the ITB.
To replace the ITB
1. Open the right-door assembly.
2. Use the blue lever (callout 1) to lower the secondary transfer assembly.
3. Grasp the small handles on the ITB and then pull the ITB out of the product until two large handles expand along the right- and left-side of the ITB.
4. Grasp the large handles on the ITB and then pull the ITB straight out of the product to remove it.
Mar 03, 2011 | HP CP3525N Color LaserJet Printer
E070
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Hello can somebody help me about the problem of my machine canon ir 3180 CI when i make a multiple copy theres an error code appear E000070-001 please help me guys
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
0003 The next HP is detected earlier than the
specific period of time after the HP of
The ITB is torn due to scratches, and the
sensor detects the tear as a HP by
mistake
sensor
Apr 06, 2010 | Canon iRC3100 Printer
Canon 3170u error E000070-0002 how to fix this problem
sensor
BE CAREFULL TO REACH THE WHOLE ITB UNIT YOU NEED TO REMOVE FIXING UNIT TOP COVERS IN PAPER DELIVERY SECTION, IT NOT WOULD BE BAD TO REMOVE RIGHT DOORS OF COPY MACHINE, REMOVE ITB CLEANING BLADE UNIT,...
Jan 10, 2010 | Canon ImageRunner C-3170U Copier
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
Sep 01, 2009 | Canon Office Equipment & Supplies
My Computer CD-R/RW Drive is faulty
you can buy this online at ebay.com
Apr 08, 2009 | Computers & Internet
I have a system error e071 on mf8180c image class.
Hi, as per the manual it says
E071 ITB home position sensor fault
Solution
Check the connector of the ITB home position sensor.
Replace the ITB home position sensor.
Replace the DC controller PCB.
Jul 25, 2008 | Office Equipment & Supplies
Do'es not turn on
The problem is with the ITB (transfer belt)
The ITB needs to be removed and cleaned or replaced here is what the manual says
0002 The time that passes
after detection of the
ITB home position to
the next detection of
the home position is
longer than a specific
period of time.
if you require further assistance please get back to me
Thank You
Jun 23, 2008 | Canon imageRunner C3100 Copier
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
