Televison & Video Logo
s
sam davies Posted on Sep 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to repair my samsung tv as it won't turn on.
My samsung tv won't turn on. It flicks on then off without displaying any picture. the red light also flicks on and off 5 times which i believe is an error code. Are you able to provide me with guidance to fit it?
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Sep 05, 2017
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006003
Points
237762
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5 Related Answers
Anonymous
  • Posted on Mar 27, 2008
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Anonymous
  • 1077 Answers
  • Posted on Jul 21, 2009
SOURCE: blue light flashing 4 times
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. I don't have the actual Service Manual for your TV to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
I hope I shed some light on the subject for you.
Anonymous
  • 4090 Answers
  • Posted on Aug 20, 2009
SOURCE: Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
there is a soloenoid type switch that fires the TV up this has failoed. its like a neon or fluoresecent tube that has a faulty starter switch light tries and tries but never quite makes it when it does get going it has that purple smear in the tube. that is the simple explanation for your problem. part is about $60 labor is unkinown as i am not in USA but looking at some of the rip off charges I am glad i dont have the bill
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 28, 2009
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Anonymous
  • 416 Answers
  • Posted on Apr 17, 2010
SOURCE: When I turn the tv on, no picture and only the stand by timer
Sound to me like your video amp failed on the C board. This board connects directly to the back of the CRT tube. It actually has the letter C on it. The video amp is IC702, PN: TDA6108JF. You can locate a vendor for the part by googling the provided PN. This amp is fairly cheap and not too difficult to replace if you can use a soldering iron. However, you must apply heatsink compound or it will over heat and fail more quickly. You should be able to get a tube from the same vendor as the amp. I hope this was helpful, best wishes.
Thomson tv repair
Flashing red indicates internal shutdown due to fault protection.
Only a tech can diagnose the fault (and hopefully repair it).
Good luck with getting it done quickly. :)
Clive.
Samsung LN26A450 screen won't work
Your model Samsung falls under a class actions settlement. These units have defective power supply boards and Samsung has agreed to pay for the repair / replacement of the boards at no cost to the user even if the unit is out of standard warranty. This sounds like the issue with your TV. Here is a link with additional information about the settlement and how to get the warranty work completed.
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
5helpful
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
TV not turning on.
2answers
Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
I HAD A REPAIR GUY OUT TODAY AND HE SAID IT WAS THE POWER MODULE. I HAVE NOT GOT A PRICE FOR THE PART OR REPAIR YET.
JASONCBFAN
1helpful
TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
