Question about American Standard Home
I have an American standard 4035 that is making a sqeaking sound, but when i wiggle the valve, the squeaking sound would stop. However, everytime it flush, the squeaking would happen again. Solution?
Posted by Cynthia lin on
Bill Boyd
    Top Expert:
  • American Sta... Master
  • 53,816 Answers
Have the valve seat rubber replaced
Posted on Sep 05, 2017
5 Related Answers
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Anonymous
SOURCE: squeaking noise in steering wheel
check your CV joint
Posted on Mar 30, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Anonymous
  • 22 Answers
SOURCE: Front end squeaking possible rotor rubbing something.
Have you checked the metal clips that olds the brake pads in the front galiper bracket. They usualy rust, break loose and come in contact whit the disc, creating a squeaking noise. Those should be replace since they are needed for the brakes to work properly
Posted on Oct 24, 2009
High pitched sqeak sound back end when coming to a stop in forward or reverse
Most squeak sounds will come from the brakes especially when being applied. Have the brakes checked for wear and performance
Oct 18, 2015 | 2011 Kia Rio
I'm getting clunking noise out of the front drivers side and a sqeaking noise.
noise when you turn? cv axle
noise going stright AND sqeak- strut
May 27, 2011 | 2003 Chevrolet Cavalier
Can you oil a samsung ml-1430 printer to make it stop squeaking
Yes, lubricate the chrome shaft with light weight oil.
Jul 30, 2009 | Office Equipment & Supplies
Jun 24, 2009 | 2007 Buick Rendezvous CXL SUV
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Squeaking noise from front end in cold weather
Bad ball joints. check out front end and make sure nothing else is bad. Good lucka nd thanks for using FIX YA
Mar 03, 2009 | 2002 Oldsmobile Intrigue
Sansui Model: TVS2542A 27" TV
check line output transformer, look for dry joints
Dec 09, 2007 | SansuiM1315 TV
Home Logo
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
