If you have the cd for win 7 , go to the bios and change the boot sequence from hard drive to 1st cd
save change
insert the cd
shut down then start again from there
the computer will select the cd unit and load the program from there onto the hard drive
when you have finished downloading all drivers from their relevant manufacturers web pages
close down and on opening get back to bios and change the boot sequence from cd back to hard drive as first option
SOURCE: usb 8.0 gb flash drive not recognized by Dell 1521 inspiron
You will need the HCSD driver/patch.
http://support.microsoft.com/kb/923293
Hope this helps
Regards
Richard.
SOURCE: Can't load Windows Mobile Device Center on Windows 7 64-bit
Isn´t WMDC installed by default in W7? Check the control panel and "view by small icons". You´ll probably find it there...
// Mr T
SOURCE: Trying to download my pictures from Canon
Supported windows Operating system
Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2
Canon PowerShot A430 has no update about the new driver software for windows 7
Try doing this direct transfer in your computer
1. Connect the camera to your computer using the supplied USB cable of your camera.
2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate.
3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow]
4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder.
** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another.
** Issue on the operating system compatibility.
SOURCE: I have recently tried to load CIV II Multiplayer
hey there welcome to fixya
you should check the system requirements on the back of your pc game cd cover and check your system on your pc to see if it has the correct drivers and graphic cards to play the game
SOURCE: Iomga eGo drive data back-up for Vista need transfer to Windows 7
try to connect it to another computer that runs vista, reformatting is never a good thing. the portable hould be read on any other computer, but if you connect to another computer that have vista take it off and keep it on the other computer for a little (like someone elses computer) and put it back on to the computer with windows 7, reformat it and try to put our stuff back on then try again.
If you have an original Windows 7 Installation CD disk -- you can perform this operation. YOu will need to do it on a computer that has a CD-ROM.
https://www.lifewire.com/how-to-install-...
