SOURCE: Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
