SOURCE: i lost my red star
The closest I am able to find on line is here
Gary
Posted on Aug 11, 2011
SOURCE: Could a get a PDF file format manual for the red star ers100 bread maker?
Posted on Mar 14, 2017
Bread pan removal:
I am assuming you have the type of bread machine that has
the little metal spring clips inside the oven compartment. Before inserting the pan always check on the
bottom of the pan (underneath) to see how the impeller "T" is aligned and turn
it with your fingers or turne the paddle with your fingers so the "T" will fit
into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the
pan in the oven and "pop" push the pan in place so the spring clips grab the
matching clips on the sides of the pan.
Also look to see if your pan has the word "front" stenciled in the lip
edge of the pan. If so, be sure that edge is towards the front of
the machine. If your pan still won't pop into place when you
push down your spring clips may need to be gently pulled out because they can
become "slack" over time. Take the pan
out and reach in and pull each spring clip up until you start to feel it bend a
little and bend them out. Pop your pan into place and if the clips don's start
to grab your pan repeat the process of bending the clips out and repeat that
until they do. Summary:
1)
make sure if your pan is marked "front" that it is aligned
properly
2)
make sure the paddle and the T underneath the pan aren't in
conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of
each other and can engage
3)
Restore the "springiness" to your clips by bending them out
with your fingers. Be careful though because the spring edges are fine edges so
get underneath them when you pull up
For bread machine parts, good used bread machines etc.
visit breadmachineshelp.com
