Temp thing freeze at the bottom and 30-32 verses 45 to 50 at the top shelf
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
SOURCE: My refrigerator freezes everything
Not only the thermostat needs to be considered but the adaptive defrost board and the air damper between compartments. Something happened yesterday and my solution was changed to a clarification request. Sea Breeze
SOURCE: whirlpool top freezer model, leaking water into
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
