SOURCE: Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
SOURCE: Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
SOURCE: gas range, can't remove bottom oven panel - frigidaire FGFB55ASD
It pulls out toward the back or the oven. I usually lift it up as high as I can before yanking on it. If it is stuck, try sliding 2 small screwdrivers in the screw holes for more yanking leverage. As a lats resort, pry it out from the front; you may damage the finish this way. Hope this helps!
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
SOURCE: Need new range top knobs.
They sell these at appliance parts supply houses. Take you old ones with you, and you should be able to get genuine replacements!
Best regards, --W/D--
