Question about Samsung Cameras
Samsung galaxy on5 manual
I would like to put a larger sd card in it. How do I do that?
Posted by Vaughn Shaw on
  • Tony Parsons
    Tony Parsons Sep 03, 2017
    Take the old card out. Put the new one in.
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Posted on Feb 11, 2009
Anonymous
  • 31 Answers
SOURCE: wnen i tried to to download the file from my mails
delete and re-install android 2.1 idk sry hope it wrks
Posted on Oct 23, 2010
Zahir Khan
SOURCE: Why i cn't install apps on my sd card for galaxy
Try installing App 2 SD from Android Market. You should be able to move the installed apps to SD card using this application. Galaxy Mini comes with Froyo and hence you should be able to use this app and move possible apps to SD Card. Moving the app to SD card also depends on whether the developer has enabled the feature to move his app to SD card. App 2 SD will only be able to move the apps which have this feature enabled by developer to SD card.
Hope this helps.
Posted on Aug 09, 2011
jomabug76
Josh Whitehead
  • 1148 Answers
SOURCE: My 8gb micro sd card is not working properly on my
Try formating your sd card in your cell phone ,,,in the settings menu,,,should be options for that,,,if not stick it in your cpu that has a card reader ,,format,,return it to ur cell,,should be good,,good luck
Posted on Dec 23, 2011
Sim card for Samsung Galaxy tablet 4?
search the top and side corners use a pin to open the sim port like now a days smartphone
Oct 22, 2016 | Samsung Tablets & eReaders
Memory full, install new SD card, how move files to new SD card?
One of these ought to work:
  1. Remove SD card, connect to PC using a card reader (and adapter if needed), copy files to PC. Connect a larger capacity SD card to PC, copy files from PC to new, larger SD card, install new SD card in phone.
  2. Connect phone to PC with USB cable, then do same process as above.
  3. Back up phone to Google, Samsung, or other cloud resource. Replace SD card with larger one. Restore phone from cloud.
Mar 02, 2015 | Samsung Cell Phones
Music disappears
is corrupted files ^_^ the prob is in ur SD card ^_^ try to put other one SD
Mar 26, 2014 | Samsung Galaxy Note 3
I deleted pictures from my gallery can i recover from sd card
Try also following software for windows photo recovery softwae http://www.comparisonandreviews.org/photo-recovery-windows.html
for mac phot recovery software http://www.comparisonandreviews.org/photo-recovery-mac.html
Dec 13, 2013 | Samsung Galaxy S III S3 16GB AT&T
Samsung galaxy y sd card is coming up on my screen damaged what can i do to put this right
I think your SD card is corrupted,because nowadays,most of SD card in the market are retrended or expanded from a old card, and android phone will store amount of data in the SD card, so it is easy to corrupted. If you want to fix your card, you can try to formate it in the phone, but it is at the price of data loss. However, if you would like to recover data from samsung galaxy sd card and save to the new one ,you can know more here: Samsung Galaxy SD card Data Recovery, and I suggest you buying a new SD card with good quality.
Mar 26, 2013 | Cell Phones
Samsung d880 manual
Samsung SGH-D880 (candy bar) cellular phone User Manual:
copy and past this link into your internet browser to see:
http://downloadcenter.samsung.com/content/UM/200904/20090414090222203/SGH-D880_UG_Eng_Rev_1.3_090413.pdf
Jan 03, 2010 | Samsung D880 Cellular Phone
Require a manual for a samsung tocco
User Manual for Samsung F-480 Tocco Here
User Manual for Samsung S5230 Tocco Lite Here
User Manual for Samsung S8300 Tocco Ultra Here
If I was helpful, Kindly Do Rate!
Regards,
Waqar.
Aug 30, 2009 | Samsung Cell Phones
Cameras Logo
52 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
