Question about Jacuzzi Home
We have a 2005 Jacuzzi Whirlpool Bath model BP43000. Digital display used to show temp, now has - - -. Pump and lights will not come on when power button is pushed
Posted by Tina Martin on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: whirlpool gold microwave over range model gh9184lq-2
F3H I assume? That means your humidity sensor has failed.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the range lights and hood fan never work, then that's a problem on the control board.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Posted on Nov 08, 2008
Anonymous
  • 68 Answers
SOURCE: jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Posted on Dec 11, 2008
Anonymous
  • 19 Answers
SOURCE: How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Posted on Feb 09, 2009
Anonymous
SOURCE: Jacuzzi - GFCI keep tripping prventing Jacuzzi
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
Posted on May 16, 2009
Alan
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
I have a jacuzzi amiga N890 that when you turn the unit on it just hmmms. It is getting power but does nothing else accept hmmm.
If you turn the Jacuzzi pump on and it just hums and no water flows through the jets then you have a bad pump.
You will need to get the brand name of the pump and the model number before you can begin your search to find the proper replacement.
Bath Pumps each have their own size. You will want to find the exact brand so you do not have to change any of the plumbing.
US Parts Center
Aug 20, 2013 | Jacuzzi Amiga Whirlpool JAC-N890...
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
My Jacuzzi H522 will not turn off sometime without shutting the breaker off. It has even turn itself on a few times so we leave the power off
sounds like you need a new temp sensor on your tub. if it is not heating and running all the time even though it is calling for heat - then the sensor is bad.
you can find a sensor here Bath Parts Plus
Jan 22, 2011 | Jacuzzi Mito, 6 Whirlpool Bath - H522
How to wire a jacuzzi whirlpool tub? What to use for wiring, timer etc?
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
Sep 29, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Jacuzzi - GFCI keep tripping prventing Jacuzzi from starting Jacuzzi Whirlpool Bath, model H240000
Mar 28, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
Mar 17, 2009 | Whirlpool Home
Home Logo
82 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
