Here's the manual, including lightbulb instructions:
PFAFF perfomance 2058 Owner Manual Changing The Lightbulb
SOURCE: Pfaff 2058 Voltage switch
There is a small clear plastic piece blocking the switch that must be removed, then use a small flat screw driver to flip the switch, you can throw away the small piece, it is only needed for shipping.
good luck!
SOURCE: How to replace light bulb at Pfaff Creative 2124?
On these machines you cannot open the left side to remove the bulb. Your machine accessory kit should have come with a rubber tool that is ribbed with a cup-shaped opening on either end. This is a tool for removing the bulb. Tilt the machine with the base facing up so you can see where the bulb is and use this tool to twist the bulb gently. It sould come out with no problem! Hope this helps!
Testimonial: "Thank you"
SOURCE: Pfaff 2058 stopped sewing - screen went blank -
You probably need a new board. If the machine isn't under warrenty it could be a costly repair.
SOURCE: need a pfaff 2058 service manual
http://issuu.com/melindamitchell/docs/pfaff_performance_2058_instruction_manual.pdf
SOURCE: I have a pfaff performance 2058 How do I lift the feed dogs
The manual may be helpful:
PFAFF perfomance 2058 Owner Manual Presser Foot Lift Changing The Presser...
