Hitachi 50HK6T74U
SOURCE: need instrcution manual for Hitachi 26" L26HO1U LCD TV
Got one from Hitachi's website.
Posted on Sep 06, 2008
SOURCE: hitachi manual needed hitachi owners manual or user guide
Hello there
Here is a link to all Hitachi Plasma Tv manuals user guide owners manual and so on
I couldn't Find your model so perehps you should check again, but no worries the link is for ALL manuals so Enjoy It.
http://www.hitachiserviceeu.com/support/guides/userguides.htm
Tom
Posted on Oct 08, 2008
SOURCE: Hitachi 42pd5200 Tv switches between on and off
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
SOURCE: Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Posted on Oct 25, 2009
Testimonial: "Thanks."
SOURCE: HOW CAN WE CHANGE TO AV ON HITACHI TV WITHOUT
Try this! Get into the menu and look for channel setup. See channel memory delete or save and add this to channel memory. Hope this works..I never repaired this model. This is only a suggestion.
Posted on Dec 23, 2009
