Question about Intel Computers & Internet
I have an older PC, replaced monitor recently. Color on screen now shows lighter going from top towards bottom on everything; also will only work properly on 1900 X 600 which is too small for me.
PC: Windows 7 Pro Serv Pack 1 DirectX 11 uses Intel G33/G31 graphics accelerator. Monitor is 2016 LG Monitor model 20M37A-B.
Posted by Danil Palm on
1 Related Answer
ghost2233
Hans Pedersen
  • 3606 Answers
SOURCE: Biostar Mother Board: BIOSTAR
Hi, you can download the driver here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Its not for windows 7 but it will probably run on your system.
X86 is for 32 bit and X64 is for 64 bit system.
Try the xp or vista driver.
Hope this will help you.
Posted on Aug 21, 2011
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Color noise suddenly appeared on screen, blacks show blue noise lighter colors yellow noise
You may have a poor connection with your LVDS cable which connects from the internal main board to the screen. This will either need to bre-seated or replaced.
Sep 23, 2009 | Samsung SyncMaster 245BW Monitor
Dell 1908s LCD monitor (new)
return the LCD to seller and ask for replacement. LCD colors should be even from top to bottom. test it with plain color as a background such as blue so you can easily see the faded portion.
Sep 04, 2009 | Computers & Internet
Color fades at bottom of screen
Although it is possible that your monitor is defect, you should first run a monitor test to see if you just need to adjust some of the settings. Go to this webpage and just follow the instructions.
The test are done best in full screen mode (F11 in most browsers).
Do you have any sources of magnetic fields next to the monitor (speakers, halogen lights, sometimes even a cordless phone can cause distortion).
If you can, connect this monitor to another computer and see if the problem persists. This way you eliminate any hardware related issues (cable, video card).
If you have any more questions (also regarding the results) come back here and leave a comment. I will check back and see what else we can do.
Feb 24, 2009 | Acer 22" X223w LCD Monitor
A white line across my screen
A chip died in the LCD screen. Definitly take it back or contact the manufacturer for a warranty replacement.
Jan 05, 2009 | Dell Inspiron 1501 Notebook
Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Aug 23, 2008 | Samsung 226BW Monitor
Acer Aspire 9810 Screen Problem
Hi No otto,
On the bottom row of keys, you will see one marked Fn, in a different color. Hodl that and look at your top row of keys. Should be one with a laptop screen, and a monitor. The little graphics will be the same color as the Fn key. Tap that once, wait, see if the screen comes to life. Usually that key is set to choose "Just laptop screen, just external monitor, or both", with each tap.
Good luck,
Jan 06, 2008 | Dell Inspiron 6000 Notebook
Monitor problem
It sounds to me like your monitor is going......if the computer itself is functioning fine, and you have even reset the monitor to the default, and still having problems, I would say it's time for a new monitor. You can find reasonable ones on ebay. I got two 19" monitors off of there and I am thrilled with them. Just be sure to check the ratings of the seller before bidding or buying.
Good luck.
Dec 01, 2007 | E-Machines 6809 Notebook
Computers & Internet Logo
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
