Question about Bunn Coffee Makers & Espresso Machines
Bunn coffee maker mrctb wont pump water - Bunn Coffee Makers & Espresso Machines
Posted by William Shaw on
5 Related Answers
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
Anonymous
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Bunn coffee maker heats but wont pump water?
I thought these are pour over brewers? Which means you have to fill it with water in order to brew? It should happen when the unit is filled first, plugged in then turned on.(see link below for MFR instructions) Aloha! ukeboy57
http://www.bunn.com/sites/default/files/care-and-cleaning/43097_0002d01_velocity_brew_manual_english-_bt_st.pdf
Mar 11, 2017 | Bunn Coffee Makers & Espresso Machines
When making coffee water dumps water all over the counter,extremly irritated.third one weve ownd w/ the same problem.unless this is easy fix i wont buy bunn again.
Please call customer service at 800-352-2866 with the model and date code. We will be able to either replace or repair your unit.
Jan 07, 2011 | Bunn BX HOME BREWER 10-Cup Coffee Maker
THE MR. COFFEE COMMERCIAL COFFEE BREWER MODEL MRCTB. IT DOESN'T HAVE ANY LABEL. MY QUESTION IS JUST NEED TO KNOW IF I CAN USE THIS IN 110 V OR 220 V. SINCE IT IS COMMERCIAL.
Hope you can help. Water runs though pot but the water is not hot whatsoever. Heating element burned out?
Commercial Brewer 8543
Apr 20, 2010 | Bloomfield 8543 Coffee Maker
Water wont come out of my bunn coffee maker
Jun 02, 2009 | Bunn GR10 Coffee Maker
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
My bunn NHBx pumps water to fast and it overflows the filter
remove the little rubber stop on filter basket but you now have to wait for coffee to finish before takeing coffee
Nov 08, 2008 | Bunn NHB Coffee Maker
MRCTB Parts
High limit switch is bad. Where can I get a replacement?
Sep 23, 2008 | Mr. Coffee MRCTB Coffee Maker
Where to buy paper filters? 10 - 12 cup are to small
MRCA8E is the discontinued filters for the MRCTB brewer. I'm on the hunt for suitable filters too....
Dec 06, 2006 | Mr. Coffee MRCTB Coffee Maker
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
