SOURCE: i want to wire the astatic tug8 microphone to a Yaesu FT 450 HF
open the radio and visually look at microphone wiring on the yaesu you should be able to wire mic accordingly.
SOURCE: Yaesu FT-26
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
SOURCE: how do i program my ft 2600m yaesu
http://yaesu.com/downloadFile.cfm?FileID=967&FileCatID=150&FileName=FT%2D2600M%5FOperating%20Manual.pdf&FileContentType=application%2Fpdf
Check page 16 and 17 of the manual. It describes several methods depending on whether you have a keypad mic or not.
SOURCE: Yaesu FT-8900 will not power up
You've prbably answered your query yourself.
Having said that, try joining yahoo group specifically for the FT-8900, they will have more info for you.
Cheers,
Peter
